Father Son 75 CB200T Rise From the Ruins
So...you're done with your seats?
If they lapped your valves: did you keep track of which valve goes into which seat?
If you're going to lap them: do you know how to mark the seats with marking blue/Sharpie to ensure an even and solid contact area?
Are you going to go with bigger valves? I'm certain you can find something that will fit with a little guide reaming.
Probably don't want to chop the guides down, but definitely want to shape the bosses.
How long before you think it can make it into lower orbit?
I'm not very helpful at all, just a lot of prodding ::)
You don't lap valves after a Serdi cut.
Texasstar, who did you find in D/FW that can cut seats for something that small? What'd it cost ya?
This bike...
Roc City Cafe said:
never used a serdi, but I like to marker up the valve and seat and "lap" it with a really fine compound to ensure a proper seating area
Thing is, when you "cut" seats, lapping would have a negative effect on the surfaces. With regular grinding that we all know and "love", lapping is really the only way to get an even seat. For most of us, that's "good 'nuff".
Sonreir said:
I assume that would reduce the life of some of the components?
they showed us a couple of drag bike motors in the shop for repairs and we couldn't resist checking them out. Guides had moved...seats were destroyed...I can only imagine what the valves looked like. The one above ran on Nitro methane with nitrous???? The ports were HUGE! A big yes on the wear and tear. We are cutting our guides for it is time consuming with steel guides. Then David said to drop it by the shop for reaming the guides.
we lapped our valves the first time but from this point on we will serdi cut. You just have to see it to believe it. Teazer has been telling us over and over to Serdi cut. After reading Vizard and Bell and how they preach about the valve and seat being an obstruction to flow...every little cut matters. I could never cut a 32 degree back cut nor could I radius on a valve by hand let alone the seat. There are 3 angles on the intake seat and the exhaust seat transitions into the bowl and Venturi of the seat is beautiful.
The great thing is we plan on tearing down this engine over and over and no lapping is needed, you pull the valve and mark it and then when it is time to assemble you pop it back in.
As far as wear and tear on our valve train...stay tuned.
www.wellsracing.com
The battle of the 20mm carbs...keihin with 750 velocity stacks vs vm20' and the pollini stacks...the mikunis look intimidating but the keihins look like they will provide the velocity to keep the Mikunis up against the ropes.
Texasstar said:
.................... Teazer has been telling us over and over to Serdi cut....................
That's only because I don't remember that I already said it. Oldtimers i think is the name for it or CRS :-)
That and the fact that there is no better way to get a precision valve job. Hand cutters and grinding stones are OK if there's no other choice, but Serdi is the filet of valve jobs and it's hard to go back to lesser cuts. .... ;-)
you and Kop also told us to score some parts bikes...now we have our cb200 cams to send off for different grinds and we scored two full bikes (one in pieces) with new gasket set, clubmans, carb kits, Etc... Great tanks, one bike will clean up like new, and Zeke will be starting his own eBay parts store here shortly if MOM has her way.
So these ones a little less 'lucky'?
Also scratch my idea of the using a 175 head the variance in 175/200 crown height is taken up by the cylinders so no comp bump
No Simo these are very Lucky for they just helped a young man named Scott go to back to college after he told the man to "take this job and shove it"...we picked them up in Buda, Texas. One was sitting in the rain on a trailer. Buda has an interesting story of a gal who robbed a bank back in the twenties, she was a student at the University of Texas and secretly married to a young man. The jury in Buda couldn't convict a woman because they didn't want to see her hang...so she walked free. Now why would a woman rob a bank unless she needed the money or she was married to a law student who new she wouldn't hang...sounds very familiar to Les Miserables and Jean Valjean's story or a story about a snake in the grass. Any way there is Great grace in Buda, Texas.
We have a secret plan for one of these bikes for Zeke's best friend. He has been wrenching everyday with Zeke on Victoria. Gotta love your neighbor as yourself and nothing says I love you like a free motorcycle... but there is one catch. They will have to restore it to it former glory first or better. Healthy competition will also make these two better...btw Neil Finn is an amazing Songwriter...hope to visit New Zealand and shake your hand someday.
I stand corrected
didn't know there were 'get out of jail free' cards in real life...
You were right about my carbs by the way she idles like a trooper at 1100 and starts first kick
Very happy Man
Great read b the way
simo said:
I stand corrected
Very happy Man
dont thank me...thank Sonreir, Teazer, Kop and company...I am just a cow chewing the cud and sometimes the right answer comes out. :)
Zeke made a tab for the steering stabilizer and we welded it to the frame. We also installed some Vintage advantage shorty brake and clutch leavers.
Our NHK steering stabilizer came from Fast From the Past and we thought Jim's email was very helpful so we wanted to share it.
"The stroke length needed for a steering damper is dependent on the mounting
points used for each end of the steering damper. The easiest way to
determine what you need is to place one end of a tape measure on your frame
where you want to mount the damper. With the front wheel turned all the way
to the right put the other end of the tape measure where you will attach
the other end of the damper to the forks and record that measurement. Turn
the wheel all the way to the left and take the measurement again. The
difference between the two measurements is the stroke you will need on the
steering damper (25.4mm = 1 inch). Pick a damper which exceeds the stroke
you have determined.
You will need an attachment point on the front forks. If you do not have one
you can use one of our fork tube clamps for that end. On your frame you will
need a mounting point for the M8 mount bolt on the damper. Many weld a tab
on their frame for that. Others make custom clamps for a frame tube.
Regards,
Jim Hinshaw
Fast from the Past, Inc.
9519 Jackson Trail Road
PO Box 606
Hoschton, GA 30548
USA
Voice 404-680-6502
Fax 770-614-0968
Skype jim_hinshaw
www.fastfromthepast.com
jimhinshaw@fastfromthepast.com
