Father Son 75 CB200T Rise From the Ruins
Good idea with custom spring bases. Gives you a little more flexibility. And cheaper than machining the spring bases to fit over those stock guides.
but the insanity continues...I am thinking we can go to 4.5mm valve stems...
Texasstar said:
A sloper frame is in our future...I have pulled that motor 3 times in 3 days
Oh come on, that's totally not the best attitude :P
I can't tell you the number of times I've pulled from Honda twins. Putting them back I suppose is just a matter of knowing which order to stab the bolts. Once you have that down it does get easier. As easy as it can get, anyway ::)
Easier to just leave the engine on the workbench and stare at it longingly...
It's been working for me for the past year or so.
Wait, excuse me for being such a brilliant idiot, but since you're only working on 175's and 200's for the time being, why not build your own engine stands?
This way you can do all of your work while the case is still mounted to a steel bracket which is mounted to a bench or something.
All you need to do is weld up some beams with holes in the right configuration. Add a fuel cell such as a tank from a roto-tiller and install simple fuel valve in the line. Put a solenoid (I know you have ten of the buggers sitting around) on the mount at some place and wire the starter. Then make a place to mount and wire up a battery. Any 12v will do but I'd go for something big so that it will hold a charge and crank over longer. Mount some spare coils and wire them up. Then take one of the spare throttle cables and handlebars (again, I know for a fact you have a dozen of 'em) and mount them as well. With these carbs not linked, I would think the easiest way to keep the cable synchronized is to just duplicate the system used in the bike. Finally, make exhaust mounts and enjoy.
Of course, it's going to look like cobbled steel waste if you don't put a big red kill switch on it somewhere ::)
This guy has the right idea.
http://www.youtu.be/Xr9aXkAAGGI
What is the cam housing service limit? Our parts bike housing are larger than Lucky even after what she has been through...
Sonreir love is a beautiful thing...the wait is worth it :)
Redliner...who needs yoga when you have bikes to work on :)
Luctor Et Emergo stage 2 tuning
http://www.dotheton.com/forum/index.php?topic=53289.0
not sure if he's already contacted you about this valve spring keeper
But maybe you can help him out
we are keeper poor...we also lost our clutch springs but I called my local honda dealer and they are available
011 COTTER, VALVE
14781-235-000 008 $2.93
We paid 12 bucks for a normally open dead man switch and we are converting it to normally closed for 3 $.
