Father Son 75 CB200T Rise From the Ruins
Texasstar said:
Stage 2 Tuning
You can't just shove a 450 in there and....no wait. Wow, that's one stout lil beast.
Teazer, what's your thought on exhaust cut-out valves? In this case, the cable kind.
http://youtu.be/UlnH9HdEC_Y
http://youtu.be/zUrXfBcQv8w
Video top Stage 1 tuning 0-60 in 16 second, 0-70 in 31 second, 0-80 1:30
Video bottom Stage 2 tuning 0-60 in 10 seconds, 0-70 in 14 seconds, 0-80 in 34 seconds
Thats f..... Cool !!!!!!
Are you still running the 18mm venturi'd stock carbs in that vid? Or is that the miku?
How's the grin?
OUTSTANDING! You've got to be happy about that. You've made some significant mods since your last outing, it would be hard to say which got you the most gain.
I would hope that after all the porting, polishing, valves, rockers, and carbs, that it wasn't just due to the shiny blue velocity stacks.
Bonneville, here you come!
Cam timing? She wants to keep revving and at 9500 k she goes super lean
I can't think of anything definitive, but possibly a fuel flow issue to the carbs? Maybe try one petcock for each carb?
Nothing else I can think of would cause such a drastic change in the A/F ratios.
How's the grin?
simo we put on the 20mm vm Mikuni's with the Polini velocity stacks. Big grin...:)
thanks Dave! My son says "lucky is twitchy and she jumps!"
Todays data
MIkuni Vm20 w/140 jets polini velocity stacks
Dynojet Research Inc.
Run Name: G:\RunFile_023.drf
Run Title: new carbs etc
Run Notes:
Run Date: 9/28/2013 4:50:43 PM
RunFile_023.drf: 90.53 °F 29.65 in-Hg Humidity: 35 % STD: 1.04 Average Gear Ratio: 165.94
s RPM x1000 hp Air/Fuel ft-lbs
0.28 4.70 7.68 12.20 8.58
0.45 4.80 8.13 12.69 8.89
0.60 4.90 8.23 12.77 8.82
0.76 5.00 8.55 12.42 8.98
0.92 5.10 8.83 12.14 9.10
1.06 5.20 9.44 11.60 9.54
1.20 5.30 9.79 10.66 9.71
1.35 5.40 10.02 10.27 9.75
1.49 5.50 10.44 10.37 9.97
1.62 5.60 10.81 10.84 10.13
1.77 5.70 10.99 11.44 10.12
1.90 5.80 11.36 12.37 10.29
2.04 5.90 11.59 12.90 10.32
2.18 6.00 11.74 12.98 10.27
2.31 6.10 12.07 13.40 10.39
2.45 6.20 12.39 13.98 10.49
2.58 6.30 12.55 14.03 10.46
2.72 6.40 12.82 13.64 10.52
2.85 6.50 13.08 13.04 10.57
3.00 6.60 13.02 12.80 10.36
3.13 6.70 13.31 12.76 10.43
3.27 6.80 13.54 12.99 10.46
3.40 6.90 13.77 13.57 10.48
3.55 7.00 14.01 13.71 10.52
3.68 7.10 14.20 13.54 10.51
3.82 7.20 14.31 13.18 10.44
3.96 7.30 14.53 12.86 10.46
4.10 7.40 14.58 12.65 10.35
4.25 7.50 14.74 12.46 10.32
4.39 7.60 14.94 12.30 10.32
4.53 7.70 15.11 12.13 10.30
4.67 7.80 15.32 11.87 10.32
4.81 7.90 15.46 11.64 10.28
4.97 8.00 15.52 11.37 10.19
5.10 8.10 15.78 11.46 10.23
5.24 8.20 16.21 11.73 10.38
5.39 8.30 16.43 12.02 10.40
5.53 8.40 16.65 12.05 10.41
5.67 8.50 16.77 11.69 10.36
5.82 8.60 16.87 11.70 10.31
5.96 8.70 17.21 12.11 10.39
6.11 8.80 17.02 12.23 10.16
6.26 8.90 17.20 12.15 10.15
6.42 9.00 17.15 12.08 10.01
6.58 9.10 16.85 11.98 9.73
6.75 9.20 16.97 11.85 9.69
6.91 9.30 16.85 11.53 9.51
7.07 9.40 16.84 11.81 9.41
7.24 9.50 16.92 12.31 9.36
7.41 9.60 16.88 12.20 9.23
7.59 9.70 16.82 12.69 9.11
7.76 9.80 16.75 13.26 8.97
7.94 9.90 16.82 13.64 8.92
8.11 10.00 17.05 15.01 8.96
8.29 10.10 17.11 16.96 8.90
8.48 10.20 16.94 18.00 8.72
8.66 10.30 17.08 18.00 8.71
8.85 10.40 16.96 18.00 8.57
9.04 10.50 17.18 18.00 8.59
9.22 10.60 17.19 18.00 8.52
9.44 10.70 16.74 17.94 8.22
9.64 10.80 16.26 N/A 7.91
9.88 10.90 16.25 N/A 7.83
MAX: 9.88 10.90 17.21 18.00 10.57
MIN: 0.28 4.70 7.68 10.27 7.83
the last dyno run with the 18mm keihin 88 jets
Run Name: G:\RunFile_019.drf
Run Title: stactic timing, short stacks
Run Notes:
Run Date: 7/26/2013 3:26:48 PM
RunFile_019.drf: 97.54 °F 29.65 in-Hg Humidity: 24 % STD: 1.04 Average Gear Ratio: 163.64
s RPM x1000 hp ft-lbs Air/Fuel
0.24 4.70 N/A N/A 11.72
0.42 4.80 7.39 8.08 11.82
0.59 4.90 7.86 8.42 11.77
0.77 5.00 8.10 8.51 11.56
0.92 5.10 8.65 8.91 11.72
1.07 5.20 9.36 9.45 12.62
1.22 5.30 9.60 9.51 13.32
1.37 5.40 10.12 9.84 12.40
1.51 5.50 10.54 10.06 11.90
1.65 5.60 10.87 10.20 12.20
1.80 5.70 11.11 10.24 12.34
1.93 5.80 11.46 10.38 12.25
2.08 5.90 11.55 10.29 12.11
2.22 6.00 11.80 10.33 12.09
2.36 6.10 12.24 10.54 12.85
2.50 6.20 12.37 10.48 13.13
2.63 6.30 12.68 10.57 12.66
2.77 6.40 12.86 10.56 12.32
2.92 6.50 12.98 10.49 12.22
3.06 6.60 13.11 10.43 12.05
3.21 6.70 13.24 10.38 11.96
3.35 6.80 13.36 10.32 12.31
3.49 6.90 13.67 10.41 12.64
3.64 7.00 13.70 10.28 12.32
3.78 7.10 13.92 10.30 11.97
3.93 7.20 14.19 10.35 11.87
4.07 7.30 14.30 10.29 12.18
4.22 7.40 14.63 10.39 12.68
4.36 7.50 14.69 10.28 12.34
4.51 7.60 15.15 10.47 12.14
4.65 7.70 15.28 10.43 12.28
4.80 7.80 15.41 10.38 12.31
4.95 7.90 15.39 10.23 12.13
5.10 8.00 15.64 10.27 12.37
5.25 8.10 15.55 10.08 12.62
5.40 8.20 15.74 10.08 12.21
5.56 8.30 15.69 9.93 11.85
5.72 8.40 15.78 9.87 11.36
5.88 8.50 15.84 9.79 11.16
6.04 8.60 16.00 9.77 11.07
6.20 8.70 16.08 9.71 10.66
6.36 8.80 16.18 9.65 10.58
6.53 8.90 16.21 9.56 10.93
6.69 9.00 16.13 9.41 11.34
6.86 9.10 16.37 9.45 11.41
7.03 9.20 16.28 9.29 11.33
7.21 9.30 16.34 9.23 11.09
7.38 9.40 16.49 9.21 10.97
7.55 9.50 16.48 9.11 11.18
7.73 9.60 16.39 8.97 11.78
7.92 9.70 16.36 8.86 11.83
8.11 9.80 16.28 8.73 11.68
8.30 9.90 16.30 8.65 11.56
8.49 10.00 16.21 8.51 11.64
8.68 10.10 16.28 8.47 12.02
8.88 10.20 16.22 8.35 11.80
9.09 10.30 16.11 8.22 11.79
9.30 10.40 15.92 8.04 11.79
9.52 10.50 15.66 7.83 11.65
9.77 10.60 14.88 7.37 11.84
MAX: 9.77 10.60 16.49 10.57 13.32
MIN: 0.24 4.70 7.39 7.37 10.58
What size are the float needle and seat? They can range from 1mm to 3.5mm in diameter on different carbs.
What air jets and main jets are in those and which needle jets and needles? Large air jets could contribute and it also may just be the main jets.
Looking at the graphs, neither torque not HP seem to be greatly changed when the A:F hit the stops. It's possible that the sniffer was too close to the end of the pipe and sucking air in.
That's a great looking toque curve but it tends to suggest that he cam is too mild and is working at lower revs than you now are looking for. You could adjust the cam to advance it a few degrees and see if that tilts the curve up, or get that Megacycle cam and let it breathe.
i just read this to Zeke and he said, "Why don't we just get that megacycle cam dad?" We have an extra cam now to send off and next month the budget will allow for it.
Teazer it is hard to believe it is the same motor. The dyno data does not do it justice. The twist of the throttle is a big grin, the torque is amazing from bottom to 9k and the acceleration is dramatically improved. Even with the stock keihins it was amazing. Where I was disappointed was on the top end until we compared the two videos. It took 1 1/2 minutes to get to 80 before and now it takes 30 seconds. We are gonna need more ponies to get us past the 5th gear barrier... So we are ordering the new valve guides today and that will allow us to rev higher so we can use our r/d retainers and new valve springs. :)
I am assuming that since we shaved .20" off our install head height we retarded our cam timing??? how far off is the cam timing in a stock configuration for a top speed run? If we degree the cam how much will that give us on the top end? We need to go to the lighter pistons and get rid of the flappy chain politician. We have the goodies on the shelf to do that but that is down the road. Since we have pulled the engine 3x this week it is making us more thorough and faster. It would be nice to have a sloper frame...
How reliable is the dyna S gonna be at higher revs and do we need to consider mounting it on the crank?
We are going back to the dyno with a fuel bottle to check fuel flow issues. Zeke and I will tear into the Mikunis today and gather the data. We did not set the float heights. We did nothing to them but check that it had a 140 main jet in it and looked at the new velocity stacks like gollum and his precious. We picked up a 150 and 155 to run alternative fuel in the future. The following is what happened when we jetted up to a 150's. BTW he was having a problem with the sniffer being yanked out to the pipe with the rear tire initially.. run 24 is with 140 jets and run 26 is with the 150's
Tex, you get by with a little help from your friends? JC version not the Beatles that is. 150 is clearly less good all through the range and it does the same top end flip up on mixture. So it's not necessarily the main jet. The fact that it goes high earlier than the 140 tends to suggest that the bowls are emptying out and the bigger main jet dries them out faster.
On some carbs it is possible to set up a fuel level gauge using the drain plug. If that could be done safely, it would show if the bowls empty out. You would have to be extremely careful with that though. Dripping raw fuel on a hot pipes would, in my opinion, be sub-optimal.
It also goes really rich at 9000 - 9500 which is equally odd. That looks like a resonance effect.
Have you ported the fuel tap yet? I like to clean out all the corners and changes in direction in the tap and the carbs to make sure nothing slows the fuel down. We use an auxiliary tank on the dyno and it seems to suck fuel out of that OK. You could test fuel flow and see if it's good enough.
Dyna on the crank is always a good idea, but racer use cam mounted and don't complain (much).
You could try a pair of 2" long rubber tubes in place of those incredibly cute Pollini stacks just to see if it's an inlet tract resonance issue.
Longer stacks and bigger top end air bleed? Seems you've made it more efficient but its reaching its threshold flow wise?
That was my original thought, too, but then it seemed counter-intuitive. A problem like that would manifest itself at lower RPMs as the exhaust pulses would be farther apart, no?
