Father Son 75 CB200T Rise From the Ruins
Redliner said:
I'll propose the question again; what are your opinions on exhaust cut-outs to vary exhaust velocity at different RPM's? On an application like this, it would be cable-operated.
Sounds complicated.
Not a performance option. Ar you thinking "Snuff r Nots" or whatever they called those valves in the end of a pipe to shut them up? If you did the computer analysis you might design something like a Yamaha EXUP valve system and racers remove them to improve flow.
We run pipes which are supposedly too large and if we lose some theoretical midrange, we don't know about it because we never had any to begin with. Stepped headers or tapered headers are a great idea and you have stepped headers even though they may be less than perfect.
You have two issues at the moment.
Lambda values drift off above 9500. Is that real or a measurement error. Fuel level tests will reveal that. Or try 5 gas analysis and check CO and HC levels to see if that tells a story. For example if bike needs more time to burn at high revs, you would see higher HC levels at high revs. I suspect it's a fuel feed issue though and we'll know that when you get into teh carbs and check the float valves.
Second issue is that you have lots of inlet flow at higher lift than your cam is delivering. Cam with more lift will help to access that extra intake flow.
And you don't want to see a picture of me with a CB160 hiding between my legs trying not to be seen. I painted one red so that people would not notice it going red with embarrassment.
ok ok ok we will call Barbara at megacycle! If I do get pulled over for speeding my story will be that I am training for the circus and see if I can get off with a warning because he will be laughing so hard :)
So if we have megacycle turn down the cam ends for bearings how will the oil feed work up the right side of the motor through the cam to the left bearing? That right side has the oil feed up the right rear post through the ear into the cam and then out the left journal into the left ear?
Nope. I was thinking power-valves, like the Yamaha EXUP.
Wouldn't that be similar to running open ?
I was meaning a bad head gasket seal affecting the dyno by sucking in fresh O2 into the exhaust
It's an obstruction, but I was suggesting it might help with acceleration by providing different and more appropriate resonance throughout the range. But teazer said that it's often removed because it's exactly that, an obstruction.
Red,
I believe that EXUP is indeed designed to change resonant length which is almost as good an idea as changing intake length as seen on the latest R1, or power valves on an RZ. That technology helps to widen the lower part of the powerband on a very highly tuned motor. So a 180HP R1 is at the same specific power output as a 36HP CB200. That's is probably not an issue at this level of tune.
Tex,
All depends on what you are trying to do with the cam bearings. If you have the cam turned/ground down and hardened needle roller bearing sleeves pressed on, you need to feed oil in through the end/s of the cam. If you keep the stock type end towers, you can keep the stock set up or convert to CB160/175 oiling.
Did you know that early CB160s had bronze bushes cast into the cam end caps? You could replicate that idea and modify your 200 end caps to take some pressed in bushes.
Circus story might work. May have to fit Cocker clown shoes to get away with that story though..
teazer said:
36HP CB200.
That sure sounds bad-ass though. What was that old Honda ad? "36hp from 444cc"?
Texasstar said:
Now imagine me on Lucky :)
It's so comical I can hardly bare it.
We never checked the left carb...we tested the right carb. From now on we will check both sides. An advantage of have dual exhaust ...
sorry redliner that bear has been used earlier in the string...:)
Redliner said:
Have you rebuilt that petcock? Have you cleaned the sediment bowl?
yes we have and as soon as we pulled out the screen it flowed just fine...won't make that mistake again.
teazer said:
What size are the float needle and seat? They can range from 1mm to 3.5mm in diameter on different carbs.
What air jets and main jets are in those and which needle jets and needles? Large air jets could contribute and it also may just be the main jets.
Looking at the graphs, neither torque not HP seem to be greatly changed when the A:F hit the stops. It's possible that the sniffer was too close to the end of the pipe and sucking air in.
That's a great looking toque curve but it tends to suggest that he cam is too mild and is working at lower revs than you now are looking for. You could adjust the cam to advance it a few degrees and see if that tilts the curve up, or get that Megacycle cam and let it breathe.
On the Mikuni vm20
Air jet is .5 fixed
Float needle is marked 1.5
Needle jet is 239-06
On the bottom of the slide is marked 5j2.0
Now we are getting somewhere. Float needle and seat are a bit small at 1.5mm. Even a stock 160 or CB200 is 1.7. That float valve needle and seat come in 1.2, 1.5, 1.8 and 2.0mm but they cost 20 bucks each. I'd recommend changing them to 2.0 for any long run.
Even better for LSR would be 22 or 24mm (NLA) 22 comes stock with a 2.0 and 26 comes stock with a 2.5 needle and seat, but let's get these zeroed in before we start swapping them out for something else.
Lucky has a larger ported petcock. This is where size matters. We drilled out the flow hole from the reserve and then both holes to the bowl. The increased the valley size in the lever.
We cleaned the 20mm Keihins and put them on tonight. So we are ready for the keihin vs mikuni 20mm dyno duel.
