Father Son 75 CB200T Rise From the Ruins
Cluck cluck...I feel very few have the resolve it takes to pluck through this thread. Nor would they research your threads on the web like we have ;) we are very grateful for your wisdom and gained experience you have shared. But is is the sweat and grit that produces results...and sometimes you get LUCKY like we have with y'all.
FYI, I just removed those pesky bits of iron sticking out of the roof of the exhaust ports. What were they thinking? In reality, it only shortens them slightly but in this case it makes a huge difference to the available area. Now to get the right port geometry and it's off to see Serdi.
I read this thread with every update, I just don't have anything to add, but a shitload to learn with every page.
:)I've been chewing the cud on what you said about cam duration not mattering. What is the relationship/optimization to port velocity and cam duration? Is this because of turning 12k? is the increase in port velocity the reason why duration doesnt matter with the little cb? Is that why the mild megacycle cam is optimum?
It isn't that it doesn't matter but rather that it's not the thing to fixate on. With a high lift cam to take advantage of the flow at higher lifts, it doesn't need to stay open as long to get enough gas in or out. In general, teh higher the revs the longer it takes to fill the pot. That's not well explained. Let me try again. At high revs the length of time available to fill the cylinder is very short, so as teh revs rise we need longer duration to still fill the pot.
But if we fill it faster, we don't need that extra time. In the case of a CB200 with stock pistons and thick rings, it will not be very happy at 12K and so it's more important to get a greater area under the power curve by lifting it higher at lower revs and relatively high lift is the way to do that.
That said, we only have choices among what is actually available and anything else we dream up is still but a dream.
The tiny CB motors generally have enough intake volume to make as much power as that motor can possibly make, so adding long duration cams just gets in the way. Go mild but go big......
Don't worry the internets as secure as a government job
And I don't plan on letting you folks teach me nuffing
Is it a matter of spring recoil? The high lift becomes long duration because the springs have to have time to retract the valves back to closed
Just stole this from the web.....
Here's a chart:
Carb Jet Size Cross Reference:Keihin/DynoJet/Mikuni
Width------Keihin # -- DynoJets # -- Mikuni #
0.0350---- 92.5--------- 92-----------86.3
0.0360---- 95----------- 94-----------88.1
0.0370---- 97.5--------- 96-----------90.0
0.0380---- 100---------- 98-----------91.9
0.0390---- 102.5------- 100---------- 93.8
0.0400---- 105--------- 102---------- 95.6
0.0410---- 107.5------- 104---------- 97.5
0.0420---- 110--------- 106---------- 99.4
0.0430---- 112.5------- 108--------- 101.3
0.0440---- 115--------- 110--------- 103.1
0.0450---- 117.5------- 112--------- 105.0
0.0460---- 120--------- 114--------- 106.9
0.0470---- 122.5------- 116--------- 108.8
0.0480---- 125--------- 118--------- 110.6
0.0490---- 127.5------- 120--------- 112.5
0.0500---- 130--------- 122--------- 114.4
0.0510---- 132.5------- 124--------- 116.3
0.0520---- 135--------- 126--------- 118.1
0.0530---- 137.5------- 128--------- 120.0
0.0540---- 140--------- 130--------- 121.9
0.0550---- 142.5------- 132--------- 123.8
0.0560---- 145--------- 134--------- 125.6
0.0570---- 147.5------- 136--------- 127.5
0.0580---- 150--------- 138--------- 129.4
0.0590---- 152.5------- 140--------- 131.3
0.0600---- 155--------- 142--------- 133.1
0.0610---- 157.5------- 144--------- 135.0
0.0620---- 160--------- 146--------- 136.9
0.0630---- 162.5------- 148--------- 138.8
0.0640---- 165--------- 150--------- 140.6
0.0650---- 167.5------- 152--------- 142.5
0.0660---- 170--------- 154--------- 144.4
0.0670---- 172.5------- 156--------- 146.3
0.0680---- 175--------- 158--------- 148.1
0.0690---- 177.5------- 160--------- 150.0
0.0700---- 180--------- 162--------- 151.9
0.0710---- 182.5------- 164--------- 153.8
0.0720---- 185--------- 166--------- 155.6
0.0730---- 187.5------- 168--------- 157.5
0.0740---- 190--------- 170--------- 159.4
0.0750---- 192.5------- 172--------- 161.3
0.0760---- 195--------- 174--------- 163.1
0.0770---- 197.5------- 176--------- 165.0
0.0780---- 200--------- 178--------- 166.9
0.0790---- 202.5------- 180--------- 168.8
0.0800---- 205--------- 182--------- 170.6
0.0810---- 207.5------- 184--------- 172.5
0.0820---- 210--------- 186--------- 174.4
0.0830---- 212.5------- 188--------- 176.3
0.0840---- 215--------- 190--------- 178.1
0.0850---- 217.5------- 192--------- 180.0
0.0860---- 220--------- 194--------- 181.9
0.0870---- 222.5------- 196--------- 183.7
0.0880---- 225--------- 198--------- 185.6
0.0890---- 227.5------- 200--------- 187.5
__________________
Here's a chart:
__________________
there are two types of mikuni jets...round and hex...I believe this chart is for the round and the vm's are hex...
I thought those numbers looked a bit off...
I'm running 115 in my Keihin right now, which should be around 135 or 140 in VM-speak.
not all the vm are the same...very confusing here is a link
http://www.mopedarmy.com/wiki/Mikuni
please don't revoke my DTT privileges for this...yes I read the moped strings
"In addition, if you want to get all guru on this shit, you can get slides with different cut out angles, needles with different tapers, and different size needle jets." We know who this is...
Ha ha I'm more likely to get all goober on this
Have you got the damn cam yet
I'll stick with the keihin's that way I'll only be wrong once... ( famous last words! )
If your hunting 22mm keihin
The 70's cb125 singles had pw22 carbs, possibly the cb100's
simo you didn't make a mistake. You just helped someone dial in mikuni carbs that have round jets who switched from keihins...
http://www.dirtrider.net/forums3/text/topic/176466-1.html
"Mikuni hex head jets are numbered by bulk flow, while Mikuni round head jets and Keihn jets are numbered by inner diameter in mm.
That's is what the Honda manual is referring to.
... and for those who are still curious
The flow difference between a Mikuni 175 hex jet and a 180 is about 6cc ~3%) . Keihn jets are numbered by jet id, and the difference between a 178 and a 180 is about .0008" (I'll let those so inclined do the math to determine the flow difference) .
Now to further confuse the issue keep in mind that air/fuel ratio is based on weight of fuel and weight of air, but jets essentially meter by volume. So we really need to know the weight of the fuel flowing through a jet to understand all this. In simplest terms fuel weight is a function of the area of the jet multiplied by the value of the square root of the fuel head pressure multiplied by the density of the fuel.
It looks like this:
weight of fuel = jet area * ( SQR Root (head pressure * fuel density)
None of the above takes into consideration the changes in fuel vaporization characteristics as you change altitude, which can have a profound impact on the final air/fuel ratio available in the combustion chamber ( the only place a/f ratio is really significant anyway) when the sparkplug fires.
As fun as it might be to look at jetting this way, the sad fact is the cross sectional area of two jets marked with the same number can vary FAR MORE than the difference in flow due to small changes in density . Good jets can vary as much as 5% cheap jets can be closer to 10% variance. "[/size]
Thanks Maritime we are learning a "shitload" also.
What does the difference in lobe centers do?
For a cam with a given duration, changing lobe centers changes the point at which the valves open and close and it changes overlap too.
Jim Dour took the -x4 and rotated the cams on the shaft to get a different LC to create the -x9 which supposedly makes a little more right at the top end and less lower down. Our tests on the 122-00 and 122-20 showed a loss of low to mid with the -20 and no measurable gain at the peak on our motor.
On the track, getting out of corners well saves more time than a theoretical advantage at the very top end. I'd recommend the 135-x1 for that motor and maybe try the -x9 with CR26 Keihin race carbs for a stronger top end for LSR runs when you are ready to break your own record.
