Father Son 75 CB200T Rise From the Ruins
Sonreir said:
That's a nice little racer, but I think the RK67 will forever be my pick for the best of the two stroke tiddlers.
50cc twin
14 speed transmission
17,500 redline
17.5 hp (350 hp per liter!!!)
Top speed of 109 mph
128 pounds (dry weight?)
sonreir I knew you would help is break the ton...
I really enjoyed getting to meet you and Zeke! That tig weld was mighty sexy, especially for a first attempt! I hope my boys have a fraction of the interest in things mechanical. About to fully overhaul the brakes and the 400, going to see if they want to "help".
I'm with sonreir on this one
I spent a couple of years living in Japan and a good stint in Italy and though I loved both and agree that the Italians have beauty down . They are prone to whimsy ( Venice being a great example ) and are likely to build a pushrod driven camchain
I remember a great conversation in japan, where my Japanese boss explained the Japanese predisposition to 'make things better' which doesn't necessarily mean faster but explains why you can start a Honda cb200 after it's been sitting for 20 years by fiddling with the points
Of note your cl160 petcock has larger daimeter outlets to flow to those bigger carbs
You now have
Ps the carbs are probably pw22 not pe22 but effectively the same
we will keep our fingers crossed and it was good to meet you!
Teazer I have talked to Barbara and the cam is going in the mail.
She told me about the "new" 135x-10 .288 lift 251 duration 105 lobes...have you tried that cam? Any thoughts?
You now have
how do we tell the difference on the carbs? Petcock is huge! And the tank feels quite a bit lighter. I will agree whole heartedly about the Japanese. One of my best friends works for Honda in Alabama and says they go ballistic on quality issues. He monitors all the warranty issues for the engineers. But he was also in love with the Morbidellis lol...however I would own a NSX over a Ferrari
Are you running stock valves?
Those numbers are very similar to the cam I'm running on my 360 (except I'm at .384" lift). I think you'll like. The low-range power drop is noticeable, but the grin on your face at 7,000 RPM will be worth it. :D
Carbs definitely arn't my strong point so check all this
But the pw is the earlier designation of the pe carb
In some early pw there's an extra air hose which runs to the airboxes which is for the idle circuit
I've got the same tank on my build to fit it to the vert frame you'll need to move the front mounts back and fab a mount bracket at the rear
yes we are runnin stock valves..when we do the cam we will be going to 57mm pistons that are 68g lighter ea...the lighter valve springs and titanium retainers with the new valve guides...I wish we lived closer so you could ride her...I like riding her better than my Triumph.
I have a 180 degree -X10 cam here and a crank to go with it, but too many other projects getting in the way. That's a lot of cam, but with the other mods it would work. Is that for a street motor or for the LSR run?
FYI, had breakfast with Giancarlo Morbidelli and Nobby Clark a few years ago at a race meeting. Nice guy and so passionate and knowledgeable.
When will we have an opportunity to break bread with Teazer? LSR all the way...we now have Charis-cb200 as a street bike.
For our do the ton run we found some racing tires that are 4 lbs ea....speed rated to 94mph...anything lighter than that ? Dunlop heavier, avons heavier, Bridgestone heavier?, michelin heavier, heidenau ?, continental cr?
Aluminum wmo x18 hoops
Tires are 2.5 x 18
Sonreir said:
Don't worry about the weight if you're going for the ton. It won't affect your top speed.
i know that speed =distance/time but lets take the morbidelli at 167 lbs if you take me a 217 lbs gorilla and Zeke a 130 lbs monkey how can I wrap my mind that we will both do 150mph top speed under the same conditions...I understand that in a vacuum ...now the problem we have been told is at Bonneville it is like running on wet pavement and that tire spin is the problem . So would we be better served by spending the money on ceramic bearings?
Top speed is all about the coefficient of drag (how well your bike cuts through the air) versus the horsepower available. So potentially, riders of unequal weight could have the same top speed if they managed to create a similar 3D profile.
Now... 0-60 times (acceleration) is almost all about weight and a bit about horsepower (at least for bikes). The lighter the vehicle, the more important weight is. The heavier the vehicle, the more important horsepower becomes.
Having a heavier vehicle at Bonneville will actually be an advantage (assuming the extra weight doesn't add anything to the surface area of the bike). This is because traction can become an issue on the salt and heavier machines mean more more grip on the tires. Furthermore, you're less likely to suffer wobble from the wind, etc.
When shooting for top speed, you want as much power as possible and as much airstreaming as possible. The rest are not primary considerations. Remember.... that's power to the wheel, though, not just power being produced by the engine. Freely spinning bearings, low viscosity oils, narrow tires for low rolling resistance... all these things will help. Eating a big lunch isn't going to make a difference. ;)
this is going to be fun...we are about to put on the fairing...we are taking a series of tires to Bonneville when I run for testing...we have the sava m11racing 2.5 by 18 on the way...thinner and a better rolling surface than the michelin gazelles
Craig Stenberg of Cone Enginneeing says that if you ask one question to ten different people on exhaust tuning you will get 12 different answers. Found the link that puts pulse velocity and pulse volume in laymans terms concerning what Sonreir schooled me on th myth of back pressure. Seemed to be well written.
http://www.gomog.com/allmorgan/exhaustbackpressure.html#faster
So what would be your projection after seeing Lucky's Dyno runs with the cl pipes at 41" inches if we put on the cb pipes cut right before the mufflers at 22" long?
If Lucky is going for maximum speed, skip the mufflers and lengthen the pipes to make up the difference. Just getting ready to leave... more on this later...
Deconstructing cb200 front wheel. Weight of stock tire, tube, wheel, brake
Tire 5.5 lbs
Wheel 8.2lbs
Tube 1 lbs
Brake 4lbs
