Junior is there any other way to ride other than WOT...lol...remember we have seen you rideJunior Burrell said:the vaccum created by attaching to exhaust is not good for the low end daily drivers. If you notice,its only used in race only applications on cars.
Texasstar said:Junior is there any other way to ride other than WOT...lol...remember we have seen you rideZeke's bike will have two engines one for a daily rider and one to keep up with you...lol Hahaha, i ain't that bad,Well ok,maybe.lol In that case,i say go for it!!!!
Thanks Teazer. Been watching this over and over! http://youtu.be/ow5cGV7bXCwteazer said:C12 is great fuel, but you will probably make more power on 91 or 89 octane street gas. We did.
Oils are very subjective. I'd run a 10W-40 synthetic as long as the motor is fully broken in (no new bores or rings) and no "friction modifiers" to make the clutch slip.
BTW longer stacks on our motor made more power to 10k and short stacks were marginally worse below 10k and slightly better from 10 - 12k.
which I would gladly pay but how do you put a price on something that is priceless like a "quest" or "discovery"? For that is what you have given my son and I and we really appreciate it!teazer said:Nice old video of Vizard talking about Minis. His comments about valve and seat shapes are important and are covered also in AG Bell's book.
1mm to 1.5mm is fine for seat width and less with a 3 or 5 angle seat/valve. Radius seats are not popular anymore as 15 degree angles basically flow the same as a radius.
When the head flows as much as you need and that's basically stock, think about valve trains and piston weight. To get it to rev, pistons must be light and rings must be thin to avoid flutter - heavy rings have more inertia than thin rings and don't seal well.
Piston to bore is the greatest source of drag even with cammed pistons, so they need to be short and even more oval than stock.
If you stick your head on a flow bench - well the bike's at least, you might be surprised to see how much it flows in relation to how much air is needed. Intakes basically flow enough already, but I may have already mentioned that. Get it on a flow bench and see both intakes and exhausts and feel free to test up to say 0.250" lift or higher.
Ours flow well at the lift our cams provide.....
Valves must be light, but titanium valves need new guides and still tend to stick. Rocker arms are also heavy and can be lightened. Titanuim valve adjusting screws and nuts are available. We had some hollowed out and broached to take a tiny allen wrench. You can make up net aluminum valve adjusting nuts too if you feel so inclined. Some of us have been doing that for decades.
Your intakes are just about the right length for the revs the motor will pull when you clean up the jetting but above 10,500 they are too long.
Any more of this and I'll have to send you a bill.![]()
yes it does...but which exhaust produces more hp? I think from what I read from Sonreirs tutorial on how to build a cafe racer the first one does.MJPriceisright said:that undertail looks awesome.
what do you think about us using our cl175 pipes going to a collector upsizing and using this shorty?Sonreir said:Again... it's a lot of guesswork to see what's actually going on there, but I'd go with option number three (bike #453).
I like the straight section (turns in an exhaust system are to be avoided), it makes good use of a 2:1 design, and the exit angle of the exhaust gases are straight backwards.
Obviously, you can't see what's going on under the fairing, but lets assume it's some nice sweeping bends (no sharp turns and no changing radius) with the pipes wrapped (wrapped pipes run hotter and keep exhaust velocities up).
For maximum effort designs, use stainless steel (it retains heat better than mild steel).
Texasstar said:what do you think about us using our cl175 pipes going to a collector upsizing and using this shorty?
Texasstar said:yes it does...but which exhaust produces more hp? I think from what I read from Sonreirs tutorial on how to build a cafe racer the first one does.
