teazer said:
Yes.
It's not so much about reversion it's about how a pipe and orifice flow. Straight pipes are good to straighten out flow but they slow things down. The decreases in area at the inlet end increases gas velocity, but what's important there is CD area and gas velocity at that point. Larger or smaller port areas either side of that are not the issue. Smaller than required chokes the port. Larger than it should be at any point leads to loss of velocity and increased turbulence.
Work out gas velocity at each part of the port on a spreadsheet and also work out the optimum port shape working from the valve back and compare the two sets of answers. That will tell you where to add or remove metal in the intake port. Vizard or Bell spell out the shapes and relative size ranges. Construct a spreadsheet using those values in each column and populate the sheet with a range of valve sizes and from that you can calculate mean gas velocity at each point, but really the only two that matter are at the CD and carb.
this is the shape we have been going for... Have not touched the floor except to lightly sand. If we were to follow Mr. Nell's recommendation our valve should be 23mm for the correct velocity on the exhaust port. 19.8 mm just below a 24mm valve seems like a huge restriction. I am wondering why Honda had it this way. Was it to limit flow for fuel economy? We will also measure the 175 head to see if there is a difference.
It seems to me that the engineers at Honda started building their engines for torque rather than hp in the early 70s. You can see similar designs in the 360 that replaced the 350 (which has more horsepower and less displacement than its ancestor).
Smaller diameters mean higher velocities and peak torque kicks in earlier. Pretty good for ridability on the street, but not too popular with the armchair racers than only look at hp numbers.
Yea we love our ponies here in Texas we have long stretches of highway where you can pretty much find out the top speed of anything. We had a Koenensigg ticketed at 200+. That also expains why it seems majority of the 160, 175, and 200 were sold on the west coast...i've heard that torque gets you started for LSR but it is the ponies that get you there :) yippe Kay yey! :)
Jrbrownie00 said:
82 pages and no finished bike? Yikes
Hey it took us 30 pages to figure out the difference between a two stroke and Four stroke....Does it count if we have an abridged string? We are still working on righty tighty lefty loosey and that is just our political views. :)
Reading through this thread was all worth it solely for this comment.
That's not counting the vast knowledge gained from Sonrier, PJ and Teazer amongst the info as well.
LOL Texasstars answer was great but this bike was finished, ridden, modded, ridden faster and is being modded again to go faster, then will be modded again to go faster again. all the while there is an ecyclopedia of knowledge being shared, I hope it never actually gets finished and the thread keeps going for many years and we watch Zeke become a world class motorcycle mechanic/tuner/racer etc.
CHeers
All kidding aside we are very grateful to everyone who has contributed to this string. Your patience, kindness, knowledge, experience, passion, and investment will pay off for generations to come. There are two ten year olds now working in our shed. Seriously ask Teazer and Sonreir...I think it was between 20 to 30 pages where I made a fool of myself for not knowing the difference it is in another string on DTT.
I do know the difference between a two and a four stroke...the four stroke is on the DTT banner more :)....just kidding Brad ;)oh and a two stroke will get you there twice is fast but is half as long..:)
Jrbrownie00 said:
I was just playing, I think it's the jealousy of my thread only being 2 pages!
no worries it doesn't matter how many pages we have...we are all apart of a bigger story call DTT
How in the heck do you know which cut will flow best before a flow bench without cutting it? The 55-75 degree cut below the seat?
So when we take it in to have it Serdi cut is this an additional back cut below the serdi seat cuts?
After measuring everything and comparing the measurement I see why the Serdi is SOOOOO important. All your porting work comes down to this for the venturi of the stock seat is not in the correct ratio to the diameter of the exhaust valve.
Is there someone you trust to undercut stock valves?
Teazer the seat pressure for the new springs are:
1.18" 51 lbs
1.08" 71
.980 93
.930 104
.91 109
Coil bind .830"
R/D is turning titanium tops and washers and they should be here next week.
We have an automotive machine shop near here that I trust but we used to get it done by a M/C performance shop that didn't make it through the recession. Ask Micah or Ed at AF1Racing who they recommend. They are two stroke guys, but can either do it in house or can probably recommend someone.
What about keeper design? Shoulder, round, square? Does it really matter or is it just a ploy to sell a complete package?
Sharp corners tend to generate cracks, but round corners are harder to lock in place, so you want "fairly square" corners with a small radius. Keeper angle must match the top cap, but unless it is way too shallow and pulls through, I don't see much difference between designs. I figure that anything offered by a reputable manufacturer will be OK.
Back the valve seat/throat area. That's the point. When you start to analyze teh port it becomes clear that there are several things wrong and some can be corrected and some would require a complete re-design, so we have to make a decision as to what to change and then we test it to see if we were right.
We'd like to see exhaust ports flow around 81% of an intake on the bench BUT if the intake flows more than the motor can use, aim for 81%^ of the flow needed to support the HP target. Any higher on either port and gas velocities will be low.
Let's say on a particular head that the inlet flows say 60CFM at .200" lift and the exhaust flows 40CFM. we would be aiming for 81% or 60 or 49 CFM. Let's say that motor needs say 55 CFM to make say 35HP at say 13,000 then we don't really need 49 CFM in the exhaust. We really only need 81% of 55 or 45 CFM. Our target then is around 45 CFM in the exhaust to let all the gas the motor can use exit stage left.
If that head still only flows say 42 CFM after porting, we'll need a very efficient exhaust to create negative (sucking) waves to drag the exhaust gas out to make it work better. If the exhaust already flowed say 55CFM, then porting it won't help much because it already has sufficient exhaust capacity.
That's why I say it's not about maximizing (making everything as big as possible) but about optimizing (making the most out of what you have).
i like to think of compromise as meaning with promise...Off to the Serdi Machine
Our NHK steering stabilizer came in from Fast From The Past thanks to ACM!
5 angle on intake 32 degree back cut
Radius on the exhaust 32 degree back cut
Pop and go...
And why I don't have to worry about the angle under the exhaust seat..."because we do a radius now"
David was working on a drag bike head that ran 4 seconds in the 1/8 mile..."hell I would cut those guides out of the way...look at this drag bike."
teazer said:
Valve guides on our race motors look like that. Restriction removed.
Yep! Thanks Teazer it is amazing what the serdi did and the difference especially on the exhaust seat
David of Wells Racing Duncanville Texas explains how the Serdi cutting machine works to Zeke
http://youtu.be/-hjWRw5hZfE
