Well Zeke and I were riding around barber on the outside Loop Road with both Victoria and lucky this past week and this happened. Anybody want to guess what it is?
Also we picked this up for Lucky for 40 bucks a Suzuki T500 front hub and brake
What is interesting is the Suzuki GT 550 and the Suzuki GT 750 front have the same braking rating...I dont know why you would want to 4LS over the 2ls???? The 550 hub is way lighter!
4LS has four leading shoes. Not sure where the braking ratings came from, but I suspect they're not actually the same.
750 was about 40 or 50 pounds heavier.
http://victorylibrary.com/brit/2LS-table.htm
hint was getting false neutrals.
deviant said:
Is that hoop aluminum? I have aluminum hoops that may fit the bill, otherwise.
no that is a steel hoop. Thanks Deviant we have a 1.85 X. 18 akront aluminum from Mikes XS . Do you have a 1.60 X 18?
I'll have to measure or check the print. I have three aluminum Suzuki hoops. Two are probably going on my GT380 and the third will be extra.
deviant said:
I'll have to measure. I have three aluminum Suzuki hoops. Two are probably going on my GT380 and the third will be extra.
you know what I hate about Tapatalk...we don't have the builds links at the bottom of the post! I will check your build out!
Did the centre screw loosen off?
I've sen it happen a few times on various Honda's. It can't come all the way out as the primary gear 'screws' it back in a bit.
The other thing that can happen is the return spring on selector arm breaks, much rarer though in my experience
I guess majority don't know the T500 is twin cylinder and reasonably light, particularly when compared to the GT550 (three cylinder) porker
The converted GT380 made a much better 500 though (around 115bhp)
it is my understanding that the Cb450 suffers from this also. Can you see how the stopper drum is off center of the rivet?
Yep, the wear on rivet is common. I have made bushes for them in the past and fitted a flat head screw into bush. Way too much work ;D
If the moving arm can be countersunk with HSS it isn't hardened properly, usually need to grind them
The 175/200 probably wears faster because it has less power so gears get stirred around more ;)
thanks crazypj we have a spare 200 engine I am going to cull through later this week. We were having a crazy good time until this happened. Next year we will be ready for parade laps. Zeke thinks he can take the old man...
