on the frame i got some plastic plugs from ace, they fit right in and looked great!!!!
wife is a saint that is for sure, she is super pumped to take this sucker for a rip!
on the tail, i had to lower the bike so much so she could ride it there is really no way to raise the tail, i got 3 point adjust links in there so i can always just raise it up in like 2 min if i want to go up any more.
ok... so since i am still waiting on a gasket i figured i would get as much done as i can! so i did... only to find, i have a bit more work ahead of me. I got the lights hooked up all the wiring done... well kind of. the tail light worked great! i had to open up and re solder the front brake light switch, bt that sucker works now... I added in my turn sigs, using some of my 10mm hyper bright LED pods, with wired in resisters.. and here is where the problem comes in...
the prev owner must have fiddled with the wires, when you turn on the left turn, works great! but the right, all 4 turn sigs flash... no big deal just got to get a wire diagram from somewhere and fix it.
everything else works great! when i click the run button i can hear the fuel pump prime, driving and brights... the whole shabang!
got the header on (new exhaust gaskets), as well as the muffler on the bike, fresh oil change, mirrors on, grips on, stator put together and on, fuel tank in, and some other odds and ends!
here are some pictures!
tail light (turn sigs on the the lower section of the liscnse plate bracket... yes they are small but MAN are they bright!!!
tail light on (before i installed the turn sigs)
headlight
stator cover and header
pipe
grip and mirror
