Honda CA77 Dream Touring Cafe Racer
vwbobby
I have removed 50 pounds from this Dream to include 10 pounds of rotating mass.
The bike was formerly know as "Slow to Go and Slow to Stop". It's now known as the "CB Killer".
Stock wheel, Coker Firestone whitewall tires - 43 pounds 9 ounces.
Aluminum rims, Duro 308 tires, lightened hubs - 38 pounds.
So with the chain conversion and the rear sprocket carrier mod that's over 9 pounds of rotational mass removed.
Replaced air cleaner and tube with a velocity stack - subtract 1 pound 4 ounces.
Modified chain guard - subtract 2 pounds 2 ounces.
Lithium battery - subtract 6 pounds 9 ounces.
Removed rear fender and engine guard - subtract 8 pounds.
Removed front fender and guard, replaced with a carbon fiber shorty - subtract 4 pounds 12 ounces.
Replaced side panels with carbon fiber subtract - 2 pounds 15 ounces.
Replaced the seat and rack with a lighter seat - subtract 7 pounds 2 ounces.
Removed baffles, tool kit and tray - subtract - 2 pounds 14 ounces.
Passenger pegs (pair) – 1 pound.
Side stand - 1 pound 1 ounce.
Air Cleaner Cover – 4 ounces.
Backing Plate (pair) 1 pound.
Kick Start lever – 1 pound 5 ounces.
Modified shifter – subtract 5 ounces.
Lightened main stand – subtract 4 ounces.
Lightened the backing plate a bit mote – subtract 2 ounces.
Total of 50 pounds removed from the bike. It’s so much more fun to ride now!
I tried to get used to the look of my carbon fiber parts and it wasn’t working for me. So I went with black. Almost done just need to sand, buff and polish.
Stock horn -15.5 ounces, Denali Sound Bomb Mini – 8 ounces. Subtract 7.5 ounces.
It's not as loud as advertised but it is louder than stock.
Main stand – 3 pounds, lightened – 2 pound 8 ounces, already reported 4 ounces. Subtract 4 more.
Round Mirrors 1 - pound, rectangular mirrors 12 ounces. Subtract 4 ounces.
Changed front fender nuts and washers for stainless self locking. Subtract 1/2 ounce.
So that comes to one pound and added to the total I've removed 51 pounds. This has been a fun project for me.
A few more pics.
The reduced weight helps out with stopping power but a longer front brake arm placed on the rear helps a bit more.
The lowered weight helps out the suspension but an adjustable Harley Sportster Shock is also an improvement.
Never did care for a heel/toe shifter.
And a pic of the velocity stack.
Replaced rear torque arm bar with aluminum - subtract 4 ounces. New weight loss total - 51 pounds 4 ounces.
Corection 51 pounds 5 ounces removed.
Finished up a carbon fiber license plate bracket.
The new weight loss total stands at 51 pounds 15 ounces.
The CB Killer
Once the rear peg brackets come off, the total weight reduction on this build will surpass 52 pounds.
From the outset of the project, my goal was to preserve the bike's iconic silhouette so it remains unmistakably a Honda Dream. I deliberately kept the original tank, square headlight, stamped frame, electric start, mufflers, and curved fenders—though I opted to retain only the rear fender. While I could easily shave off another 35 pounds or more, I am completely sold on how it looks right now.
The transformation on the road has been remarkable. Acceleration, braking, shifting smoothness, gyroscopic handling, and top-end cruising speeds have all seen dramatic improvements. It feels like an entirely different machine, and I couldn't be happier with the ride.
The heel/toe shifter would have been worth some cash to anyone doing a restoration, cutting it wasn't a particularly smart idea in my opinion. The spline pattern is standard to just about all Honda's, Yamaha's and Kawasaki's (Suzuki use a coarse spline on earlier bikes) so you could probably find a used aluminium one that is a lot lighter than a chopped up stock one. Same with the brake operating arms, you can get alloy ones from Honda dirt bikes about 1/3 or less the weight.
Those strainers on velocity stacks are worthless, you reduce the opening by about 60% and end up with less air than stock.
You can check if you know mesh size, I think McMaster Carr gives area reduction on different mesh sizes
Thanks, but I didn't find the things you posted. I still have the stock heel/toe shifter, could not find an aluminum that was lighter than the one I modified.
The stack is much better than the OE air filter and tube in my experience. It also shaves off 1 pound 4 ounces.
The brake torque arm I made weighs in at 3.5 ounces vs the stock one at 8.5 ounces. Couldn't find a lighter one.
None of the parts that originally came on the bike were modified. I have the 52 extra pounds to make it look like this: (including original tires)
or this:
or bags and a Buco shield to make it look like this.
This look is my favorite.
It does look pretty good, the CA is difficult to cafe, you did a nice job.
Little surprised you still have the chrome covers over fork pivots, they were usually rotted out on the bikes I saw (along with fork bottoms, I got pretty good at gas welding rebuilding them and the top spring pockets)
It looks like it had every available extra when new?
1965 CB72 was the first 'real' motorcycle I ever fell off, twin leading shoe front brake on grass wasn't exactly smart. (I was 13~14, early 70's)
Always liked the look of the motor, could build a mini Laverda 750SFC from a CB72/77 (coming full circle, Laverda 'copied' the motor around 1968)
I can't think of alloy gear lever at present, all modern MX bikes use folding ones so it would have to be something from 80's, maybe XL250 (the one with 23" front wheel, not earlier or later models) that was built lighter than most. Some Kawasaki off road bikes and a few Yamaha DT/YZ/YZF but I can't think of models.
One thing you need to be careful of with alloy brake torque arm, if it's too light it can break, did you use 6061 or 7075 ?
Personally, I wouldn't use 6061 less than 1/4" thick and 3/4" wide, even then I would be checking for cracks pretty regular. (OK on race bikes that get checked 'all the time', not so much on the street)
7075 is about 1.5 times stronger than 6061 but I would use same dimensions. (I need to get some to make operating arms for CB77 front brake, I've done some weight reduction on bikes in the past)
Alloy rims and lighter tyres are always a massive improvement, I like Michelin or Continental, forget which one uses Kevlar instead of steel for beads and carcase but front wheel went from ~40lbs to under 30 (I think it's in my 390 build from 2009?, had the weight savings 3~4 computers ago)
Thanks, much appreciated. The bike was in really nice original shape when I bought it and the chrome guards came with it. For the first few years, it was a shriner bike and then stored away by the owner for a long time. Still only has about 3,100 miles on it.
I used 6061 aluminum for the brake torque arm but I'll keep an eye on it. Still trying to find a CNC one that will work with no luck so far.
