Honda CB-1 Concept
Rick4004
"What's happened? Tell me everything."
"Alrighty, then ... picture this if you will."
I've had this idea in my head for quite a few years now. In the mid 2000's Honda introduced a CB4 Interceptor concept.
I thought that a CB-1 would make a good starting point. A big plus to a CB-1 where I live is the insurance is about as cheap as you can get, less than $500 a year with my discount. As soon as you go over 500cc, or the bike gets labelled as a "sport bike", the insurance nearly doubles.
I started computer modelling before I even bought a bike and I quickly found out at least one reason this bike never made it into production. With the fairing and tank modeled as close as possible to the concept bike, there was virtually no turning angle before the lead clip on hit the fairing, and/or the trailing clip on hit the tank. I did a lot of refining before I was able to get decent clearance at both the front and the back. My old wrists cannot stand low clip-ons anymore either, so I moved the bars to above the triple clamp height.
This gave me a basic outline to start working from, and the hunt was on for a donor bike.
I would have loved to pic up a nice low mileage bike to start from, but CB-1's are extremely rare here in my part of Canada, and the used prices are pretty high all across Canada. A nice used one with mileage between 30k - 40K kilometers are usually in the $4000 - $5000 range.
I managed to find a really high miler (88,000km) for a decent price.
Many would have been turned off by the mileage but it ran well, and my thinking was that any bike that has reached that kind of mileage and was still running well must have had regular oil changes and probably spent most of it's life on the highway.
I stripped the bike completely down to the frame, pulled the engine, and got to work. On all my previous bike builds I have CAD modelled absolutely everything before I start building anything. This is a effective technique that prevents a lot of build errors and wasted effort, but it take a lot of time, and I wanted to try to get this bike done as quick as I could. There was no way I had the time to measure and reverse engineer the engine and frame to get it into my CAD program, so I started looking around for some free scanning software to try to scan everything. After much frustration with no progress I came across a post of my local fakebook 3D printer group for a guy here in the city that does 3d scanning. I got a hold of him and sent him some pictures of the bike and told him what I wanted done, and his rates were pretty reasonable, so I booked a time to get things scanned. The bike I bought came with an extra frame so I dropped that off at his house for scanning. He then came over to my house to scan the engine.
This all took most of the summer. In the mean time I was selling parts on ebay to raise funds and slowly buying little bits here and there. I was able to put the spending in overdrive in the early fall when I sold the CB400F endurance racer https://www.dotheton.com/index.php?threads/honda-rs1000-cb400f-mini-replica.76284/
I had decided that I wanted to use a CBR400RR NC29 swingarm, CBR600F2/F3 wheels, and a GSXR750 front end that I had on hand. With cash in my pocket from the endurance racer sale I started collecting parts. I bought a CBR600F3 with a hole in the crankcases for just to get the wheels.
NC29 Swingarm from Japan bought thru Webike.
Cheap chinese Garrett GT1241 clone turbo. I had good success with a IHI RHB31 clone on my old SOHC CB400F. The GT1241 looks like it is good for about 20% more HP than the RHB31. I am looking at around 85HP at 8psi.
Nissin radial calipers, GSXR-750 rotors CBR600F3 wheel.
The GSXR rotors needed adaptor plates machined to match up to the CBR wheel.
New disk, CBR600F3 rim and brake carrier, NC29 swingarm
After a lot of screwing around with the CBR600F3 cush drive, I happened across a VF500 Interceptor cush drive in a box of parts and it uses the same drive lugs and rubbers as the F3. A bit of machining to line up the sprockets and we had a winner! New 520 chain and front sprocket, and a leftover rear sprocket from my old turbo 400 build and that was one headache taken care of.
I had a spare Microsquirt sitting on the shelf, but I wanted to run staged injectors on this bike. I have a set of throttle bodies off of a CB400F Super Four that comes with tiny little 140cc injectors. Should be good for idle and up to about 50hp, so I am going to run a set of CBR600RR shower injectors that will come on when the boost starts. The microsquirt couldn't handle this so I had to shell out for a MS3 PRO Mini ECU. Budget blown. This set up with the wiring harness and a couple of sensors was well over $1200 CDN with shipping and taxes.
As this was all going on I came across another CB-1 for cheap. This one was only a few hundred dollars, but it was about 3000km away. I found a decent price on shipping so I went ahead a bought it, mainly for the engine. It has about 60K km, still a lot, but less than the engine that I currently have. It's rough, but a buddy wants the wheels/fork/brakes for one of his projects so it will not cost me much in the end, and having spare parts for an older bike is always a good thing.
Nice project. Just an FYI, if you need easy rear gearing, the Suzuki GS500F rear sprockets are 520 and the same bolt pattern as the VF500F rear cush drive. Certainly useful to check gearing and such before spending on the much nicer rear sprocket you are running.
EX119X - Thanks for the gearing tip. When I was building my SOHC400 I ordered 2 custom aluminum rear sprockets. I wasn't sure how long an aluminum rear sprocket would last so I ordered an extra. I've ran that original sprocket for over 30k KM and it is still in good shape, so the extra going on this build isn't costing me anything in my mind :D
Mounting the CBR400RR swingarm turned out to be a real nightmare, mostly of my own doing. For starters the swingarm was too wide at the pivot tube to fit into the frame, and the CB-1 only uses a 15 or 17mm pivot bolt, whereas the NC29 uses a 20mm bolt. I realized that the easy solution was to use the smaller pivot bolt and make up some inserts for the swingarm bearings, but I really wanted to use the 20mm bolt. That meant I needed to bore out the pivot holes.
I set the frame up on the mill but the setup wasn't solid enough and rather than cutting the boring bar was just flexing away from the cutter. I switched over to drilling out the holes and they drilled really easy, but not on center. The holes were visibly off center. SH*T!!!
I needed to get the hole back on center. If I couldn't get it set up in the mill the only other option is to try and line bore it. I made up some spherical spacers that mounted in the swingarm pivot cups on the frame and pieced together a line boring set up that used a 1" annular cutter.
After the holes were opened up and enlarged I made up inserts to bring the inside diameter back to 20mm. After much faffing around the swingarm was mounted.
That's looking good. I had the same problem but I cut the pivot points out & machined new ones up to suit the new swingarm. There's some pictures of it on my posts.
I agree that there were multiple ways to tackle this. I picked one path that I wouldn't follow again. I'm beginning to think that this will be a temporary frame build, and once the bike is complete and running I will likely pull it off the road and over the winter completely redo this section of the frame. I have lots of experience with "Bimota" style frames using machined aluminum side plates mated to a welded tubular frame, and I think I will go down this route at a later date.
Out of time photo , but here is one of the disk adaptors on the mill. The chips give an indication of how much material was removed.
I entered all my measured data into my suspension software to position the lower link mount, and upper shock mounting locations.
I compared the results to my other build, labelled "B28", which was designed to mimic a CBR600RR. With the 108N/mm spring that comes from a CBR600RR shock I think I might be a little soft. I recalculated with a 140N/mm spring and that got me back to being comparable to the B28 line. I also have a stock CB-1 spring that is progressively wound being force tested right now. Once I get the results of that I'll plug those numbers in too.
Using these dimensions I located my upper and lower shock mounting points for a CBR600RR shock. I was planning on converting the CBR600 sock to a remote reservoir, but it looks like a CBR1000RR shock might fit without moving the reservoir.
This lower mount will get a bunch of bracing, according to the design requirements. I loaded the model to 6G, and braced the mounting area to handle the loads. There are a few hot spots that would likely cause issues if you were to constantly load to 6G, but that is a worst case scenario that you are only likely to see hitting an extreme bump at high speed.
Is that Tony Foales software that you are using to calc the wheel force?
Another milestone today, but not without some drama. I got the intake plenum basically finished, just need to add a snout for the intake tube to attach to, and fill in the sides and the rear cutouts. I am going to run stock CB400FS 140cc injectors in the throttle bodies, and then CBR600RR 190cc shower injectors in the mounting bodies.
At the other end, after a ton of detail fitting, the turbo manifold is complete. everything is so tight that I almost painted myself into corner where you can't install the radiator after the exhaust manifold is in place, but if you install the rad first, then you can't get the nuts installed on the exhaust clamps for cylinders 2 & 3. I finally 3d printed a little tool that held an M6 nut and allowed me to get up behind the rad and behind the exhaust tubes and get the nut started on the stud. From there it's a 1/4 turn at a time to tighten the nut. Luckily it's only two nuts.
I am going to have to change out the wastegate actuator to get the intake tube running to the right location. Not a big deal as the supplied actuator is probably set for 12-14 PSI which is too high to start out with.
Progress has been slow of late. My milling machine motor packed it in so I was out of commission for a few weeks. It's all up and running again (nothing $900 couldn't fix) and I was able to get on with fixing my latest problem.
You can see from one of the above photos that I had just enough clearance from the oil filter to the turbo to remove/install the oil filter that came with the bike when I got it. I ordered up a new filter and when I went to install it, guess what? It was about 1/2" longer than the filter that was on the bike. I did some research and it seems the two filters have different pressure relief valves in them.
1. I didn't want to take a chance with the wrong filter.
2. I needed to take off some pressurized oil to feed the turbo and feed an oil squirter. (More on that later)
So I decided to build a remote filter housing. These are common on Turbo Hyabusas so I looked at a few photos online and designed my own. Quite a bit of machining but it all went fairly smoothly.
Everything proceeds at a snail's pace. Sometimes you spend weeks working on a few items and when you are finally done you look at it and think "This should have taken a few days". And you probably could do a second on in a few days without all the thinking, fitting, rethinking, refitting.
The turbo needs a straight drop out of the body for the oil, so a small tank allows for that, plus adds another half litre or so of oil capacity. The oil pan extension drops the oil level by 55mm to work with the tank. The oil pump is chain driven and actually ran partially submerged in the oil. With the drop in oil level I had to add an oil line feeding a squirter to spray oil on the chain.
For better or for worst I decided to go with an external fuel pump. This style of pump is used on the larger Honda Foreman ATV's and the CTX1300 cruisers. It was a major pain to find a place to fit it that was low enough to allow for gravity fill from the gas tank. This location might be less than ideal because it is right above the hot engine. I am going to wrap it in heat insulation. This spot is where the factory coolant overflow tank went so I will have to find a new spot for that too.
