New Jersey sr500 tracker/scrambler
NJ I think you said you are going black, if you do a polished lip will look great so you can do that then change tires and it makes it a lot harder to hurt the paint. also waiting until the paint is cured vs dry will be a good idea.
HA! Hillsy good call. NJ sand the primer off the disk bolt area and mask over before you paint. If you look at my wheel that whole part is masked off.
I give this kid more cred than most haha... he takes the heckling with a grain of salt and throws it in our eyes... Keep up the good work Jersey as long as it gets finished and ridden... you are leaps and bounds ahead of most who come here HAAHAHAHAHAHAH!!
thanks for all the tips guys I might sand down the lip if I do end up chipping the paint while removing the old tire or installing the new one and when i do the rear I will take the tire off this time...maybe ill even install the new one and actually tape it off :P I just want it to last long enough to save for some powder in the future
I knew I should of put something to cover that area on the disc...ill clean it up I didn't paint the other side in that area...well I did but I wiped it off before it dried 8)
im almost at 200 posts!
BTW, a deck of cards makes a great mask to paint rims. Just slide them between the tire and lip and fan them out, overlapping like a poker hand.
You ever see something that is incredibly useful, know for a fact that you are going to forget all about it, then remember after you have done the thing the hard way?
Good thing this tire was scrap but I can do that for the next one ans have the new tire installed!! Thanks man ;)
Went to the dealership by me bought fork oil 15$ :'(
Put the oil in 6inches from the top pumped the forks a bunch then made sure they were both 6 from the top again put the springs in and capped em off
Installed the forks line everything up torqued everything down took pics realized it was all fuckin backwards flipped it around the right way and re-torqued?
Cleaned the old chipped paint off the bars apparently you can't paint over anodized shit :/
Painted the rim nice and black tire looks great night out it on eBay and get some money for it 8) :o jk
Shops a mess
This new throttle assembly doesn't have a screw in part for the cable wtf?!
I gotta trim these gators but not sure how yet
Tons to search tomorrow and slowly getting to where I can bring this thing upstairs
Forgot I popped open my box of foam I have enough to screw up ten times hopefully I get it right on the first try though 8) 3 inches thick high density
