New Jersey sr500 tracker/scrambler
as long as you made the seat pan maybe one of these:
Nj732port said:
In which pixel is the thing you want to show us? Try to use another pic taking potato
If I'm correct, remove that screw and you will be able to insert the "matchstick head" end of the cable in the slide, then put the tab you removed with the screw, and snug it down.
It seems you have the correct cable, but using it the wrong way. Any way clearer pics of slide and cable end would help us help you.
Keep it up
Sent from my GT-I9300 using Tapatalk
you do need some common sense to understand the pick, but your assessment is correct... remove screw, slide stay off insert cable end and reinstall stay
I hate it! mine wont be completely flat it will have a stepped rear area but I don't like the café style curve on that thing
Keep it up
that's off of google I think your guys comps just suck cause the pics are all clear to me!, ill take pics of mine when I get home, I know how to install the cable and all of that im just saying my handle bar end does not screw in to the throttle housing not really an issue because it has a thick rubber cover that holds it in place pretty snug to the throttle housing....I guess I was trying to ask does it matter if my cable doesn't screw in to my throttle housing as long as it is secured and functions or is there some unforeseen disaster ahead
If your throttle cable is not secure to the housing on the handle bar end, then it can jam up and/or not throttle down on decel. Is it supposed to be screwed in or is it designed that way? Whatever it is designed to be is what it should be.
the screw stays in place along with the die-cast standoff piece ,only need to remove the drop in ,formed metal keeper deal, to change cable
when changing needle or clip position on needle then you gotta hit the screw and remove the die cast piece
on the seat yeah sorry i was harsh but do some foam sculpting like what tuna showed would be killa
but rememer to have the carb top and spring with cable stuck thru before you attach to slide,then once cable is in place secure go in again pull back spring and drop in place the formed metal keeper
conversely the fornmed metal keeper comes out first if changing cable or needle situation
I hope you both stub your toe! or run out of beer! I found the correct cable I need but I gotta wait to order it so ill be tempting fate for a while with this once it gets going
DohcBikes said:
oh didja now
no one else gives you credit for anything around here why expect anything more from me!? j/k thanks for the help did you see my post in the chat letting you and kamn know im "watching" it on ebay for when my bank isn't being cheap
