"Patina" The 1973 CB175 Cafe Racer
Re: "Patina" The 1973 CB175 Cafe Racer
Hey Matt, just sent you a PM. Can you verify my wiring to my relay once more? I have a blue to headlight switch, black to connector back to headlight switch, green to connector and white to coil. Can you tell me which ports they connect to on the relay?
cafe mike said:
Did you turn the idle screw out yet?
Yeah I'm asking how far. Saw that the slides raised and lowered .
Won't fire up again. Just want to verify wiring with Matt on the relay.
PM sent.
When you turn the idle screw in the idle goes up. So don't turn them all the way in. Visually look at your slides till the bottom out. Then try to start it. Turn one time. Try it again. Again visual
We are back to wiring.....please hold........ (Plays elevator music). ???
Hahaha we are getting somewhere. Since it's a bump only is ill to have my kill working lol
Back to the carbs for a second, screwing the throttle stop screw in raises the idle, so how many turns out is a good place to start at least? I did notice the slide move up and down as I adjusted, and both seem to grossly rise and fall at the same rate with throttle opening. I did notice that one metal crimped end of the throttle cable came out of the brass nipple on top of the carb cap causing the left carb slide to raise higher than the right.
I start at bottom. (Screw backed out).... Crack throttle until it runs. And raise accordingly, at least to get it to run
Ok that was confusing me. By "bottom" I thought you meant running the screw all the way in until it "bottoms out" so to speak. You're speaking of doing the opposite. Back it all the way out to lower RPM way down to start off.
considering you fiddlled with the cable adjustment at the top of the carbs you will want to synch the carbs for even cable pull(so slide opening is actually even by adjusting cable housing)
posickle stick method works fine just make sure the sticks measure the same
Bottoms out = slides
Screw out....
Like BSA said.. Make sure your slides open evenly...
Visual look at you carb slides... Bottom them put with screw out then . Screw in until your slides start moving up... Then stop.... Do other carb. Now you know when you screw one half or one turn in. It will lift (idle) the slide the same, got it?
Screw out....
still need to do a synch though by adjusting at top of carb
I'll do the sync for sure. I just need to get it at least in the ballpark so I can begin to tune.
Screw out....
Perfect. That makes sense. Why is the air screw screwed in to seat?
cool you CAN get an even smooth idle and THEN synch the slides
it is not neccesary to synch first
however you must pull the air filters to synch so it just makes sense to do it first
carry on
for a reference point
then you can count the half-turns out in order to get them close to the same
Your done with that part. You went to seat and went 1-1/2 turns out right?
