"Patina" The 1973 CB175 Cafe Racer
Texasstar said:
I want to try one of these
I don't know what it is, but I want to try it too.
Re: "Patina" The 1973 CB175 Cafe Racer
Weber Carburetor Syncrometer SK Type 1-30 kg/h
Thanks Texas! Never seen it before either...
Better than this one.
I wish someone would make a nice intake boot with a port for syncros
Wish I had that nice one when I had a Toyota 22r with dual side draft webers
Just need make sure the center support isn't in the way
We plan on making a skid to test our motor out of the bike
I can bless you guys with mine... Just need a flat surface to mount to..
Pm your address and I will send it out (don't worry I get huge discount to ship)
Woah that thing is sweet.
thanks Mike what I meant to say was we are going to test it on our skid before we install in our bike. We have one just need to hook up some controls and a kill switch ;)
xb33bsa said:
use 2 (one in each carb)excactly same size,MEASURE THEM WITH CALIPERS !, popsicle sticks on EDGE inserted gently so that they hold up the slides
they needs to be fully under the slide not just at the cutaway
use a light and look in make sure the are evenly seated on both sides basically they will be propped up by the needle and the bottom edge of stick flat to the floor of the throat of carb
now when you very slowly open the throttle the sticks should be released from the slides EVENLY at the same time the sticks are being used like a feeler guage kinda
just use one or the other cable adjusters at the top of carb to get this right
XB how about this video? You approve? Judging from the angle of the stick it looks like he may just have it under the cutaway, not the needle too?
http://m.youtube.com/watch?v=Dgh91t7JnNY
Your not going to get "it" under needle
xb33bsa said:
goddamit,1rst timer, how hard fucking hard can it be to follow instructions are mine tjat fucking un clear!!!!!!!!!!!
Well you're sticking around so you must like my inquisitiveness.
Well I didn't think so but it seemed like his directions explicitly said to not have it just under the cutaway.
Sometime you need to read between the lines. You know enough about what's to be expected by now. I want you to stop finger banging the keyboard and get it running. Enough with the high beam relay. Just start that thing up
you need to have it slid through the carb ON EDGE so that when the slide springs force the slides down,it contacts the front edge of the slide,not the cutaway
when you move the slide upwards from there it will be more or less still vertical because it will be proped up leaning against the needle
you cannot ever get it under the needle anyway, the needle never comes that high ::)
xb33bsa said:
you need to have it slid through the carb ON EDGE so that it contacts the front edge of the slide,not the cutaway
Thanks man. I getcha now. I'll update after I play around with it.
I understand where your heads are at. I promise I do. However, as my alias says, I have no experience. I don't have any "lines" to read between.
I am in this to learn. If I have knowledge, I can build multiple bikes. If I just bull in a china shop it, I'll learn nothing.
The headlight relay is wired in with the kill switch. I would rather have that safely functional before I run and superman style bump this thing off again :)
