cafe mike said:Sweet now I have all the info I need to time my bike, thanks guys!
Not sure if you seen Texas build a plastic cover. I'm gonna do the same but I have a buddy who makes moulds for slot car bodies. He places a thin acrylic sheet it. Heating element is above it. Soon as the sheet Starts to droop he shut off the element and vertically lowers onto a vacum table with lots of holes and within 15 sec it's done. One I make the mould I will make them availble.1sttimer said:Wear your play clothes...
cafe mike said:Not sure if you seen Texas build a plastic cover. I'm gonna do the same but I have a buddy who makes moulds for slot car bodies. He places a thin acrylic sheet it. Heating element is above it. Soon as the sheet Starts to droop he shut off the element and vertically lowers onto a vacum table with lots of holes and within 15 sec it's done. One I make the mould I will make them availble.
You know it!1sttimer said:Sign me up.
xb33bsa said:no tighter than 60in/lb
maybe there is a crack that opens when hot
some powder to find the crack use talc not cocaine
the "sensor" you use to figger overheatin' is a plug reading
on a wot run pull in clutch and hit the kill,then pull plugs for a look
Duchat said:If I could afford cocaine I would pay someone to fix my bike.
teazer said:What you are looking at are the electrodes for signs of overheating. Use a jewelers loupe or big assed magnifying glass to see how the side and center electrodes look. If they are burned clean for too long, that's an indication that combustion temperatures are too high - could be wrong plugs, too much advance or too lean.
They won't show signs of poor heat removal though or of oil breakdown - only if there's excess heat generated in the combustion process.
Take a digital pyrometer with you and check around the head when you do the plug chop to see where is hottest and how hot it is.
xb33bsa said:no reajusting of the clutch should be needed as long as the gaskets are close to the same
while you are in there i would pull of the rotor and remove all the uneeded garbage on it
Everyone brings it home new. Hears all the great stories about how great they are. And never clean the trap. It's labor intensive, or unknowingly overlooked1sttimer said:I was wondering what all that black crap was. It is hard. Nasty deposits from years if sitting maybe?
