1sttimer
Over 1,000 Posts
Well we have an engine problem.
I finally got the kickstart lever to depress however it's only engaging the clutch shaft, not the crank. The top end is entirely free and the pistons rise and fall and the valves opening close like they're supposed to.
When I try to kick the bike over in neutral it only spins the clutch shaft but doesn't engage the crankshaft internally somehow. We took the right side engine components off all the way down to the case. Everything spins freely on the countershaft but for some reason it's just not turning over the crankshaft.
When you put the bike in gear and try to bump it off the transmission engages the back wheel through the chain so everything is fine there. We're also getting a spark through the electronic ignition so it's safe to say I could technically bump the bike off to start it but I don't want to add oil knowing that I want to get the kick start working right and have to drain it back out again.
What is messed up that's preventing the crankshaft from being engaged by the countershaft? Is countershaft even the right word there? I mean the shaft that runs through the clutch basket.
Help?
Help?
