Texasstar said:
^***first timer he needs to be replaced with you...if we can do it anybody can do it!
Yup, I completely agree. My next project bike will be that way.
I'm a mechanical engineer by schooling, product engineer primarily for injection molded plastics by job title.
The school I went to was unfortunately very theory based and not very hands-on, so I'm trying to catch up on that front. I can look things up in a book and tell you why it happens, but touching an feeling that concept makes things much more real.
This was actually the first time I've been inside an engine, though I had classes on internal combustion and all that jazz. My biggest fear and problem is that I'll mess something up. Gradually I'm getting over that, but the OCD makes me want it done right the first time :)
It's awesome that I have this sounding board at my disposal. You guys are great.
i tell my kids that failure is part of the equation of success. The fear of failure is what must be overcome. When we give ourselves the permission to fail we are really given ourselves the pathway to success. One of the character traits I want my kids to develop is grit. Grit is not formed by handing kids entitlements nor is it formed by handing everybody a trophy. It is formed in the furnace of failure and in that furnace learning to persevere.
Here is a fellow mechanical engineer to inspire you http://youtu.be/hyht48MAOTw
This was very eloquent, Texasstar, and I'm sure your kids will be better off in this world because of it.
this was yesterday. Mom's harmonic balancer on her crank went out. So to put thing back in harmony It took us 7 hours to finish the job. We tried the good buddy bar, heat, we tried to use the weight of the van setting up a teepee with two breaker bars we finally resorted to this...http://youtu.be/jvkkGMKl83w
So...just watched a "race prep" video from Triple Nickel 555" and she turned her engine over by grabbing the clutch basket with her fingers. Granted, no cam end play issue or coil spring pressure but still...suspicions reaffirmed again.
Just take it one step at a time and you'll work out where it's too tight. Start with the cam towers.
Texasstar said:
Any news on the engine?
Thanks for the interest, sir.
Unfortunately not as of late. I asked my "mechanic" to check the cam end play and to take the valve cover off to see if there's anything going on in there. I'm not sure why I had to ask him to do that.
On another note, I gave him until tomorrow afternoon and I'm going to pick it up to see if I can get anywhere with it myself.
I need to find another kicker mechanism. Saw one on ebay that was a decent price. I'm waiting to see if anyone responds to my "wanted" ad before buying it.
Pick it up and do it yourself.
For two reasons: It's easy and you will learn really fast. We'll try not to let you fail or fall.
Grab a manual and parts diagrams from any of the on line sites so you can point to a part on the diagram and we'll all be on the same page.
Thanks guys. I'm pumped to get it back and try it myself!
I think the first stop is to take the tach and points housings off and/or release the cam from the crank. That way I'll be able to know if it's above the pistons....then I'll work my way down?
Don't take them off yet. Just loosen the screws a couple of turns and see if that releases the tension. If it does, then remove one at a time carefully.
If you end up removing the tach housing, I have a good 1:1 scan of the gasket that goes behind it. I think it's up in the "Gasket Library" thread, but if you don't see it let me know and I'll email it to you.
So good news!! Turns out camshaft end play was the issue!
Loosened the tach housing and everything let loose.
The gasket set that I bought only came with one gasket and not two for the top end. Once the gasket was added underneath the tack housing, that little difference made the engine spin freely.
You can now turn it over by hand, very little effort.
Hope to have a video of her purring for you guys soon...
That's great news but it makes me want to go and slap your mechanic. DId he really think that he only needed a gasket on one end and he didn't bother to check. Pretty shady.
Yeah, agreed.
You said it well. When it comes to replacing the kickstart mechanism, I'm going to try to ride the summer without it and then replace it this winter myself. I'll need you guys' help :)
