teazer said:
And let us not forget that a fatter bluer spark is a sure sign of more spark energy and that means it also uses more battery or generator energy, so make sure that the battery is well charged and stays that way.
For sure. Got my new r/r should be good to go
Mike, this the kit you got?
http://www.ebay.com/itm/Dyna-Ignition-5-ohm-Dual-Output-Coil-DC7-1-Wires-DW-200-Harley-Davidson-/400547857830?pt=Motorcycles_Parts_Accessories&hash=item5d428345a6&vxp=mtr
It's the only one with wires on ebay. What are the end caps they have on the wires in that pic?
Ah, ok. Couple more questions about that: my EI came with specific resistor caps to use. Are the caps that come on this this the pus-on type? And how are the 90 degree caps usually attached? Threaded somehow? Sorry, never done it :/
We are running non resistor caps because we are running iridium plugs. I would want 90 degree end caps.
The 90 degree caps have a brass screw that you screw the cap into the wire to make contact with the wire core. Let me take some pictures for you.
Ok. So the straight caps in the ebay kit are non-resistor? I guess my question is are those straight ones replaceable with the ones I have from my EI?
these are on our other cb200 they are resistor caps and screw into the wire
Stock cap replacement is NGk LB05FP 8030 black 90's
Yes that one off eBay
Side note: check the wire before you do anything. Mine came with small slices in them. That was ok because you need to cut and crimp on one end while the other is screw on
Haven't checked the continuity throughout the coil. I'm headed to pick up the bike from the shop this week so I can do all this myself but until then, I'm just speculating. I'm going to check continuity in both spots before I go buy anything.
Which ones were screw on, the kit on ebay? Sorry I got lost in your comment which you were referring to :)
The end caps ( one that clips onto spark plug are screw on. The other end of wire (check your wires for damage) gets a crimp connector and slides in like an old coil on a car.
Ohhhhh got it. Is that why the crimp connectors are included? I was thinking that was in case you had bullet connectors for the wires on the side if the unit instead if ring terminal connectors. I gotcha.
So for the connections on the side, you have ring terminals from your harness? The stock one used bullet connectors.
You still can use your bullet connectors. I just cut off the wires that are on old coil
Just a matter of cutting off the old leads and putting ring terminals on. Doesn't matter what's positive or neg even though it comes with a diag
