Re: "Patina" The 1973 CB175 Cafe Racer
cafe mike said:
I tried to call ya.
Sorry man I had to step away for a sec. I only have my work phone but ill call you back here shortly if
You're available
You're available
cafe mike said:
Make sure you run the wire into the coil all the way before slipping your boot around coil insulated post, I think your not going in far enough to make continuity
Ohhh ok now that's something I haven't tried. I'll give that a shit here in a bit.
1sttimer said:
Not through the resistor caps and wire but into the coil?
That's sticking the test leads into both resistor caps. And wires plugged into coil
We'll hurry the f up.. I need running sounds on your end...
cafe mike said:
Looks like you posted something. But nothing is showing
Apparently I havent figured how to post YouTube videos. It was Toby Keith's little less talk and a lot more action.
The best I can do. Make sure that your crimp is round so that it fits into coil. Measure depth of coil. And make sure your wire is going all the way down
Thanks sir. I got 19 mm depth and I'm going 19 mm in. Still no continuity. I'm baffled.
xb33bsa said:
did you strip the lead and fold it back ?
Yessir. I am getting a really solid connection that takes some effort to get in and out of the coil, really snug. I even tried to take the connectors off and shove the bare wire in there to get continuity. Nothing...
I have about .5" of bare wire that's in contact with the connector metal.
I'm baffled too. Your getting good continuity when you test wires with boots on (and ohms)
Your coil tests good. And when you plug in wires your getting nothing. Even when you change your meter selection? I have auto range.
Is it a copper core wire?
The interesting thing is that as soon as I touch the leads to connect the circuit, I instantaneously read a resistance on the order of what I would expect. Then it zeros out. If I remove one test lead and reconnect, I read a resistance again for a second then it goes away.
What readings are you getting on your coil
Across the terminals I'm getting about 16.75 k-ohms. Across the wires individually I'm getting about 4.7 each. If resistances add then I'm getting about what Mike was getting across the resistance caps (about 25 k-ohms).
