xb33bsa said:you may need more slack in the single cable adjuster at the grip
did i not fully cover bench synching already?
popsicle stick gets the cable pull even you still nede to synch the cable slack idle screw position as it pertain =s to the idle slide opening1sttimer said:Bench sync = Popsicle stick then yes. We're good there.
In other words. Back out the idle screws. Then see if you have slack in the cables. Pull on the cable and make sure they move up and down a 1/16". Does the bike rev up when you turn the bars at all. Do you have slack in the throttle tube. Again back off the idle screws. Check cable slack. If not turn in one time the cable adjuster for each carb. Then play with Popsicle sticks.xb33bsa said:popsicle stick gets the cable pull even you still nede to synch the cable slack idle screw position as it pertain =s to the idle slide opening
no once you set the carbs even with the pop stick you dont want go back and mess that upcafe mike said:In other words. Back out the idle screws. Then see if you have slack in the cables. Pull on the cable and make sure they move up and down a 1/16". Does the bike rev up when you turn the bars at all. Do you have slack in the throttle tube. Again back off the idle screws. Check cable slack. If not turn in one time the cable adjuster for each carb. Then play with Popsicle sticks.
My bad. I understand your way. I have never tried this way. Can't wait. Try it. Thanksxb33bsa said:you can do it thusly back off the idle speed screws the ones that lift the slides...
use the single cable adjuster at the throttle grip to achieve an idle and then carefully one side at a time sneak up on the idle speed screw adjust until it contacts the slide and you hear a change
then back of on the single cable adjuster to acheive slack and then back of each idle speed screw evenly to lower idle
I'm more trying to translate that his cables might be tight. So as a base line make them loose and redo everything you saidxb33bsa said:no once you set the carbs even with the pop stick you dont want go back and mess that up
I sync them as well. But I would rather have the cables have slack ( but making sure I hit wot ) let it the slides rest on the idle screw. I just count the exact turns on the cable adjusters at the top of carbsxb33bsa said:no once you set the carbs even with the pop stick you dont want go back and mess that up
I would make sure you have play in the throttle tube. Adjust cable if not. Then move to the cables and see if the cables on top of both carbs have play when when the idle screws are backed out till they make no contact with the slides1sttimer said:This guy...?
First off I noticed that my throttle cable is routed TERRIBLY. I have no idea why I did that. The section before the split is going a much longer route than it had to. I'll adjust that first. Gaskets are coming in tomorrow and loctite by Tuesday. You can't buy 518 locally....so I'll try all this when I get her together. Thanks for holding my hand through it
cafe mike said:I would make sure you have play in the throttle tube. Adjust cable if not. Then move to the cables and see if the cables on top of both carbs have play when when the idle screws are backed out till they make no contact with the slides
cafe mike said:Are you charging. Because I'm not.
HerrDeacon said:You should be fine. What brand gaskets are they?
