I use no-toil. It has a solvent so the none green formula stinks good. Make sure you get the cleaner. It's the only cleaner that will get the oil out, it's powder form. Once you mix with warm water the old oil falls right off. And your up and running in 15min instead of couple hours.1sttimer said:Is there any opposition to using motor oil as foam air filter oil? UNI's website says to not do that because it can damage the vehicle, but I'm having a hard time seeing as to how that is possible. Would K&N oil work as well or are they different formulations and work differently?
