stubsryan
Air leaks do cause high idle speeds on fuel injected engines as the injector compensates to keep the lambarda sensor in the right range.
Air leaks after a carb will mean that cylinder will be sucking less air and fuel from the carby because some of the air is bypassing the carb.
Also fuel only cools an engine after the maximum saturation point of fuel and air for that cylinder because beforehand it will combust. That’s not applicable in this situation because no one wants an engine running like that in the first place. Alternatively if you sprayed a small amount of water in with the fuel you can get some efficiency gains through cooling, otherwise it’s a mute argument.
Slides are working just fine. I’ve balanced the cylinders to an acceptable range.
Some of the things you are saying doesn’t make sense. I’ll sort it out and if you are right I’ll give you a shout out. We will see soon enough
