Slowly going from the street to the track..but right now i want to punch babies!
surffly
Over 1,000 Posts
I wanted to get into vintage motorcycle racing for a while now.
I came across a 1971 CB350 that was in good shape, had a NYS title and was cheap so I bought it.
The plan is to sort out the basics and use it on the street for the spring then over time turn it into a Formula CB bike.
how she started.
the sissy bar and ape bars were tossed and a stock set of bars went on.
doing a major tune up and such
-Duro street tires
-EBC brakes
-tubes
-motion pro cables
-points
-condenser
-plugs
-OEM carb seals and O-rings
-rebuilt front forks
got her running the day that I picked her up but found a bad carb diaphragm that Im going to have to find a replacement for.
im collecting a few parts for when the race build starts
CB750F front end
Dyna Coils
GT750 front drum brake
its going to be fun...
Re: Slowly going from the street to the track.....well maybe
Way cool. Will make sure I follow this one!
I have those same tires Got front, rear, tubes and rim strips for $90 hell of a deal!
seeing as I am planing on turning the bike into a track bike I didnt want to spend to much on street tires.
they will be fine at street speeds
rockcitycafe said:
is that a gt750 front drum? you cheeky monkey you...
indeed it is... i am damn jealous! get some proper liners for those brakes you could stop a truck!
yesum its a GT750 4LS drum
to be legal in class i need to keep the stock liners but open to any shoes.
honesty its over kill but looks BA
1978 CB750F forks
very long lower legs for strength.
was looking for late VTR250 forks as they are double bushed but couldnt find a good set at a good price.
That GT hub is seriously cryogenic.
I'm looking forward to following this build.
im on the look out for light weight rims to work with my drums
also on the look out for a 1978 CB750F tripple. or cb550 35mm tripple.
found out that the early CB750s had narrower front ends and i think it will work better with my GT750 drum and CB750F forks so im on the hunt for and early triple.
got a good deal in 4 so i bought them.
a set of CB750 K1 triples are on the way yo me.
love using rare....ish vintage parts that a resto guy would pay big bucks for on a race project.
well i guess i was wrong about the early triples being narrower. but all the same ill be fine and make it work.
most of the guys at the track run cb750 and cb550 triples.
i think ill run cartridges in the forks and get custom straight rate springs for the forks.
also need to mill off a few pounds off the GT750 drum too.
Very cool man, looking forward to the front end swap. Just finnished mine and went with late style XS650 forks and triples. 35mm, cheap, and lots of inexpensive aftermarket parts for them.
Whats the difference between the width of the GT drum and the clearance between the forks?
For lightweight rims look for XS650 rims, they used shouldered aluminum rims for a bunch of years and you can get them for cheap usually. Most were 18" rear and 19" front so you might want to get two rears if you're going on the track with it. Only thing to look out for is # of spokes. I dont know what you're drums are but the XS rims are 36 hole.
bob.
when i had the front end off my CB750K1 i tried to see how the GT drum fit and it looks like its going to be an easy install.
most of the race guys are running cb750 forks that i talk to. some say the F is better because of the taller lower legs but im not sure.
ive been keeping my eye out for XS rims.
yes i need two rears.
they are 36 hole
the thing is to modify them for the different spoke angles of the much larger GT drum
might have to just bite the bullet and get rims from buchannas.....
So....why didnt your run a CB550 front end?
550 forks arent as long and wont stick up thru the top tree as much as the 750 forks.
Also.....if you use SL350 triple clamps(upper and lower) it bolts right up to the stock frame....and you get a double pinch bolt lower triple clamp for the 35mm tubes. Thats the setup I use on my AHRMA race bike.......works great.
honestly i got a great deal on the CB750F forks so i figured i would run them
like the idea of the SL350 triple
what years had the 35mm forks?
also what do you mean about the double pinch triple?
