Swagger said:
Keep in mind, we *BUILD* shit here......
Chances are pretty good that you could if you put your mind to it, make the spring you needed from a hardware store part, same with the screws...chances are pretty good that even if you couldn't find exactly what you need in a well stocked Ace Hardware, you could get something a little long and cut it down. Same for gaskets and diaphragms (nytril is your friend).
Your other option would be to replace it with a universal petcock and make an aluminum adapter.
I know I sound all pissy, but i'm over budget/time/patience, haha. This should have been a ten minute fix, but now its an issue I wasn't planning on.
Herm, Yes its CB200T I gave them a call and the retainer clip and the spring are not avail. Like Swager said, I'll figure something out.
Have a little bit of progress photos
Laid more fiberglass on the seat. It was a little flimsy. Now its pretty stout.
Rear view: license plate bracket mounted. Still need to add running lights for the plates
Clear coat on the tail. Turned out amazing! The two stage clear is so so much harder than rattle can clear. Plan on door guard edging around the bottom rim and the hole at the bottem is for a retainer for the wires.
Homemade Herm rear set.
I had a bolt mounted above for my old shifter but with the new bearing it allowed me to mount the shifter with the peg. I cut the bolt off, but I'm going to wait awhile to grind it back smooth and repaint it.
I used a piece of water pipe as the rear spacer. The bolt is grade 8 and the washers are hardened. Drilled a hole for the toe piece to slide through and welded it.
Here is the spray bottle, clear and hardner I got at NAPA. The bottle was about $5 and the aerosol refil was $3
