THE RD FROM HELL
NO EXPLANATION NEEDED
It kinda hard taking shit from s majure and not pulling this card bork bork bork
Tonight i locked down the top spring mount it still needs boxed and braced .i also did some measuring and alot of grinding and desided to build alum axl plates outta a old swingarm this will let me pull the length as close to the magic 20' inch of the rd400. i need 13 inchs for the wheel and tire, about 5 for the spring breathing room and 2 or 3 inch for the brace and dog bones. i got a 1 1/2 to still cit outt the swing arm but im gonna do it in two 3/4 cuts just in case it gets to close. it eazy to cut twice its harder to put metal back. here some pictures in no real order
Here is the swingarm working progress the first pic is a junk yz125 swing arm the second is the ex swing arm im tring to fit the axl plates to. there is more work to be done the steel box will most likly end up cut at the most forward chalk line befor everthing is said and done. a few bolts will hold the plates in the box tubing, plus the spools will run through everythng and weld on both sides as a last line of defence
LOOKS GOODER THAN I IMAGINED..........I wonder what Swivel would say.. :-X
Ha Swivel would say...."The angle of the swinger and shock will cause the dreaded death wobble that will make your mothers uncles brother want to fuck your sister and you should just buy a SR500 cause they are the only bikes worth ever owning...." or so stupid shit like that.
Nice Work Brad.
Nice Work Brad.
Well put Maritime ;) haha
Awesome work Brad!
That bench stand for the frame is goddamn genius. Off I go to the cutoff wheel.
Lookin' good sir.
Heh. More than just the quality of the build, you are some entertaining motherfuckers....
Brad,
It might be a good idea to tie that top shock mount to the two rear down tubes. It's probably OK, but the mount is applying a lot of force quite a long way out from the weld which creates a powerful moment that may prove troublesome over time.
Thats tonights project, to box in those tubes and tie in to the up rights. i just ran outta sober last night so i decided to quit befor i did something i would regret (hints the second frame in this build) plus its got a very unfinished thrown together look at the moment. i think building the mount in sections will give me the best shot at the good welds becouse i can get to everthing eazy
