That is awesome. Totally sort out the cornering clearance issue the stock pegs create.
Not too sure where you are on the foot control levers, but going to pass a couple of things along early just in case. First, and this may be obvious, the lever arm that pulls the brake rod needs to be at 90o or greater to the rod. This looks to not be possible with the lever in your pics as you will want the pedal to be angled down considerably with the brake not being applied. The actuating arm would need to be rotated anti-clockwise considerably to be in an appropriate range. The second less obvious but potentially more important issue is the location in space of the pivot between the pull rod and the actuating lever. Ideally, this would be directly coincident with the swing arm pivot. In this location, movement of the suspension will not affect the action of the brake. Moving away from this location in any direction will cause motion in the brake mechanism when the suspension moves. Generally it is extremely inconvenient to locate the pivot in this ideal spot, but moving it rearward along a line between the SA pivot and the rear axle has only very minor impact. You can not move the pivot up or down from this line very far at all without very noticeable "pumping" of the pedal as the suspension follows bumps in the road. Move the pivot far enough and the brake can actually become applied with enough suspension movement - very bad! One common solution is to use a cable like that used on the front which eliminates this problem completely, but is a lot more complex than the simple rod and lever scheme.
Personally, I spend a LOT of time sorting out the riding position. The person who will be riding the bike needs to spend at least 15 - 20 -30 minutes sitting on the bike, with the seat at the correct height, hands on the bars selected and adjusted, and feet on mock ups in the expected position. That would be a pretty short ride, but will indicate if changes are wanted. It does not factor in wind resistance, but in my experience, that is less important a factor on setting the ergonomics than is popularly thought.
Of course, getting the seat, bars and pegs just right with no concern for the associated machinery invariably makes for a lot of fabrication work to get all the controls to work equally well. I think it is worth the effort to have a bike that is really comfortable and fits your purpose perfectly.
Foot position you are exploring is way to tight for me, but I really like the upswept exhaust adapter idea! Gives the ability to clamp the exhaust way after the stock foot peg, improves the look a whole lot, and improves ground clearance.
If these are parts you plan on selling you might consider making the position adjustable somehow. I personally I never ride with the middle of my foot on the peg, only on the balls of my feet, so that position would be way too far back. Rizoma has some nice eccentric adjusters that look pretty good too. just my .02
Thanks for the feedback! This body and footpeg position would not be my choice for a daily rider or even a weekend thrasher, but this build has pretty much one purpose, so I figured things could be pretty extreme. Good point about making adjustable ones Doc. I am not sure I would offer these to customers though - my products are already niche enough, let alone racer position footpegs haha. I did try placing my toes/balls of my feet on the pegs though because I do that sometimes like you too. These printed brackets and the plywood template were not quite strong enough to test that properly though. Jp I'll respond to you below...
Jp I spent a long while pondering the brake linkage. The gear linkage is pretty straight forward but yes, the brake is more challenging. I looked into all sorts of solutions, even converting to cable linkage instead. But then I remembered I have a spare stock brake pedal that I can modify. I think the following solution (see attached sketch) will work. What do you think? Hope it's clear enough, the proportions are not quite right but I think you get the gist...
And in your response to comfortable body/riding position. I already assume this won't be comfortable ;D I'm going to make my daily rider much more back and wrist friendly though haha
Why have a setup with two levers doing the same work? Can you not make it so that your rearset lever is pulling the brake linkage without the second lever?
That is a good solution. The factory places the pull rod connection point at pretty much the only good spot, so incorporating the original portion can't go too far wrong. It would be a good idea to consider the leverage of the oem setup as you will likely want to have similar effort required in the new setup.
Great, thanks. I'll post a mock up as soon as I have one.
These were my exact thoughts in the beginning as well - why add mechanical complexity through an extra linkage?
Then it struck me in the middle of mocking up such a solution, then I confirmed my assumptions with google. The answer is simple, you do not want a control lever attached to a moving part - the moving part being the swingarm. The reason is twofold: The action of the lever and its throw is no longer linear to the brake arm - because the angles and position of it change in relation to the brake lever through the rear suspension travel, plus, the required force also changes. You would even run the risk of weird feeback through the brake lever as the suspension goes through its motion.
Just google any OEM rear set linkage solution (nowadays its mostly hydraulic disk brakes, but look at drum brakes) and you will find an interim linkage that disconnects swingarm to brake lever ;)
The real reason is that you want the lever pulling the brake drum at the swing arm pivot. If your pedal is not that at the swing arm pivot then all that makes sense. Not sure why that didn't occur to me when I asked the question.
On another note, I got my Antigravity small case 4 cell battery over the weekend. This will fit nicely under the seat 8)
https://hobbyking.com/en_us/turnigy-5000mah-4s1p-14-8v-20c-hardcase-pack-1.html
That’s the battery I use in my RD.
I’ve also used a pack half that size.
With the large pack, if it starts within in a minute of kicking it’s good to go. I wish I had gone for a modern charging system though. Getting rid of that excited coil system would have saved me another couple of pounds.
if you use a cable to actuate the rear brake, the cable becomes the "disconnect" between the pedal and the swingarm motion.
just like the hose on a hydraulis set-up.
That battery isnt suited to bike use unless you have a balance charger setup...the antigravity one has basic electronics to prevent over/under charging and keeps the packs balanced....Only issue Ive found with the gravity batts is, if there is a tiny drain the protection circuit wont cut the power before a cell drops to low killing the battery..so if sitting for a long time disco the battery.I use a Anderson 50A connector https://www.jaycar.com.au/anderson-50a-power-connector-6-gauge-contacts/p/PT4420 to quick disconnect the power should I park it for a while or for emergency disco if it all go's bad :)
If I had a nickel for every time somebody lectured me on batteries I’d have some serious change.
I ran a low voltage disconnect for quite a long time and I have logged each cell voltage over several thousands of miles. I recorded them at 1hz, but also recorded total V as well. I concluded that as long as I didn’t have issues starting or a failing charging system that the low voltage disconnect wasn’t needed. Sure it would likely ruin the battery if I pulled the cells under 2.5V, but at $30 for a battery who cares? As far as balance charging, there’s never been a need. The cells have always remained very consistent and balanced. I do have a balance charger that I can if I need balance the cells, but it hasn’t been out of the tool box in two years. Even the 2500mah battery works just fine. I have converted my regulator and rectifier to solid state units, but that’s recommended for all modern battery chemistry’s.
All of the said, battery management circuits can be had for like $6. Combined with the battery i posted you have the equivalent of the Antigravity but at a massive cost savings. Finally, I’ll add that Antigravcity batteries a few years back were not managed, they pitched their overpriced RC car battery charger to all their customers. In summary, if you know what you are doing my battery is absolutely suited to bike use.
Quick edit: I’ll add that my low voltage disconnect was automatic, not plugging or unplugging required. Also, my RD draws less than 5 amps, but it will charge at nearly 6amps, so I end up running a 10amp fuse. With that in mind, a 50amp plug is an absolutely silly sized plug for a motorcycle, it’s what we use to jump 2 liter formula cars.
One additional note, while the price advantage of the RC battery is nice the main advantage is packaging. I didn’t like the dimensions of the AG battery within the packaging constraints of my build, those were rather considerable but resulted in a 270lbs RD350.
Meh each to their own....sounds like you have it sorted......I prefer a simple elegant solution as cost isnt always a factor for me ...anyway getting off topic sorry OP;)
