hell if your up this way come by! you can ride the piss out of it! ill grab my other scoot and we can go for a ride!
sorry this is a long one... i have just hit a road block and i need any help i can get... i took a bunch of pics so i hope that makes it easier...
ok... so here is the issue with the exhuast... #1, i dont weld... i have to either get one of my drunk ass buddies to do it or pay to have it done... $ is not somehting i have alot of right now... so i am trying to think of a way to make this work. #2 I need back pressure on this bike, these carbs are a bitch to tune in, without it.. and i am already running V stacks so it is going to be picky anyway...
this is the pipe i am working with.. the stock headers have to be used cause of oval ports and again not a welder
now...
i have a set of stock 01 1200 C (sporty) mufflers, that i wanted to try and use.. however, the pipes sizes are off wia bit... the headers are 1 1/2 ID, 1 5/8 OD... and the mufflers are 1 3/4 ID, 1 7/8OD... (i know i woudl have to have a muffler shop make me an adapter so that is a cost i know i have...
the original plan was to just hook them strait up, i would make a hanger off the rear set perch, and be done... well the shifter and brake lever will hit the muffler... and be SUPER quiet from what i hear
shifter hits:
Brake lever hits:
so if i move the muffler in 1 in they will clear, so the muffler shop would have to make me an adapter that has an S that brings the pipe towards the tire by 1 in, and have about 3 in total in length to do it...
distance for the S bend
pipe that 1 in towards the tire clears easy
what i was wondering... has anyone ever made their own baffles? i know in the 70's my dad used to use 2 wing nuts in the drag pipes he had to help make tuning a bit easier...
do you think if i was to put 8 wing nuts in the pipe, 1 row as far in as i could get them and the other about 1.5 in from the end.. that i could get enough pressure? i have even heard of putting a washer on the other side of the wing nuts and using a spring to that conects to the wsher and then the end of the pipe to hold it in there against the nuts to help tune...then i could then just get some turn outs and put those on there.. tell me what you think? or any other ideas... i am lost... think low $$$ an low welding! ha ha ha
home made baffels:
