WIRES! CB550 issues
sxecafe
You think the Carpet Pissers did this?
Hi,
I am wiring up my 550. I tested a bunch of things last night. Continuity for all wires is good. I have replaced the plugs with new units. Mine turned to powder when human skin came in to contact.
I have a this battery:
It's reading this:
I feel like that's low. I have tested fitted a few things but really, only LEDs. Shouldnt be drained that much. I have a trickly charger but wanted to be sure that the gel cell batts are cool to go on there before I start charging.
Also, this is the first vehicle I have ever wired. I have changed a few basic components before but nothing like this. I am using the stock wire harness, which was in great shape. I put new connector pins on it (like I mentioned) and the following have been replaced:
- New Reg/Rec unit (picture below)
- Two pin turn sig relay (picture below)
- Emgo Ignition Switch (picture below)
I tested the Alternator and everything comes in under manual specifications, so it looks like that's good. The battery, as seen above, looks low but even still, I cant get running lights, turn sigs, anything to read... Don't know where to go from here. Looks like all my components are good but I must be wiring something up wrong or out of sequence...
similar boat as you, trying to get this figured out as a complete amateur.
You may want to start with the fuses. check that they are good first. then, with the fuse out, see what you are reading in each fuse slot. if you are not getting 12v, then you can trace back from there.
that helped me get a couple of things sorted. I am still dealing with crossed signals, and things not working right, but i was able to rig it all so i have 12v everywhere i should.
If you need photos or anything, i will do what i can.
Where are all the places you should have 12v? Would you mind either sending a list or showing me where you obtained that info?
Yup. I use 1 amp, but it shouldn't make too much of a difference.
As for the wires which have +12V, that's pretty much all of them depending on what is currently switched on. A good rule of thumb is that so long as the ignition key is on, you should be able to get +12V from any solid black wire. There will be a few others as well, but for Hondas, black is hot and green is ground. You should also be able to get +12V from any red or red/white wire without the key being turned on, but running anything from those is not advised as they it often unfused and unswitched. That is, if it doesn't blow up it'll at least drain your battery. :P
Got it. I will check it all tonight.
Another question, when wiring up the new relay, should the wires go grey in the harness to red on the unit and black on the harness to black on the unit or Grey-Red/Green to Black...
If you're talking about the digital turn signal flasher, the red wire from the unit should connect to black from your harness. The black wire from the unit then connects to gray in the harness. Unlike your stock relay, there's no need for separate grounding.
Got the battery on there and got 12v to most everywhere I should be. Tested the red, black and rear running light... All 12v. The brake switch web triggered 12v. I even got the headlight to light up for a sec, until I blew a fuse (drat)... I'm getting nothing from the turns tho. Prob something with the way I've wired the relay...
I have to find real homes for these plugs tho. That's proving to be confusing.
You have probably just shortened battery life by about 50%
Lead acid batteries should be charged at 1/10 amp hour rating, 9A/hr= 0.9a charge
AGM/sealed can be charged at higher rate for shorter time (but, in my experience, it shortens life expectancy of battery)
Couple of hours may not do too much damage, I thought you had left it overnight
2 Amps for couple of hours should be fine, helps break down deposits on plates IIRC
Still working on configuring the wires. The more I work on connections, the more I am revamping my ideas and cutting away excess length that I am finding that I dont need. I am also finding that I can quick connect things that I didnt intend to and bullet connect other things. Blah blah blah... I'm rambling I know. Now on to the real reason for my questions:
I need to extend the cable from the starter motor quite a bit as I moved the battery to the back of the bike and now it wont reach the negative terminal. Anyone have any ideas/experience with this? I bought another cable with the intention of splicing it together to get the length but I dont feel like that's the best option. Can I take out the old cable from the starter competely?
Either get a pair of jumper leads and separate them, use amplifier power cable from stereo store, cheap stick welding ground or power lead (you can generally buy it by the foot at welding suppliers)
Any will be better than splicing heavy duty cable.
Because of the extra length a heavier gauge will probably be a good idea
Just an update. I got a pretty decent chunk knocked down. Lengthened the starter cable. Had to change the ends of the battery cables and then I wrapped them in sleeving. Changed some of the reg/rec connections to bullets too. That helped to clean a lot of stuff up. Next I have to consolidate the gauge and control wires and then hopefully I can call it a day. Still not getting power to the signals but Im confident I will figure that out soon.
I got through some milestones tonight while working on the front of the wiring harness. I started trying to hook up/clean up the new acewell rip off speedo I purchased. Through that, I was able to:
Get the head light to consistently stay on:
Mock up tail lights to stay on:
and get the speedo unit to power on
WOOOO!
Then some weird stuff started happening: Here is what I posted on the thread for this speedo, but I think there is a deeper issue I am facing.
I have a 1974 CB550. I wired up the oil, neutral, brown power and high beam from the speedo unit to a quick connect. Then, on the bike/harness side, I had oil (blu/red), the neutral (light grn/red), the (what I thought was) tach light (brwn/white) and the brwn/red (that's what hooks to the high beam switch in diagram diagram). I have the grn from the unit connected to the grn ground of the bike. I also have the black power from the unit connected to the black of the bike.
If the ignition switch is turned on the first click, the unit powers on but without back lights. Once I switch the ignition to the second switch, the unit powers off... I tested the brwn/white and the black (which should power the unit) at the ignition switch. I read volts on the multimeter with it turned on the first switch but they went away once it was turned on to the second switch. (I realize I need to charge the battery again)
First Position:
Second Position:
If I hard wire the power for the head light to the brown wire of the unit, the light will stay on. However, is it possible for the unit to not go on until the motor is running and the system is charging? Why else would the switch kill black and brwn/white?
Also, I cant get flashers at ALL, but I'll save that until later.
second click is parking light, shouldn't have any ignition/lights power.
Usually the tail light will be the only thing with power.
