WIRES! CB550 issues
Red IN to switch, black OUT to fuse box?
I forget if there is an internal 'bridge' in switch connecting black to brown in the ON position?
Brown is lighting wire, it will be brown/white after fuse box if I remember right? (haven't looked at a wiring diagram for a while)
sxecafe said:
I also have the black power from the unit connected to the black of the bike.
If I hard wire the power for the head light to the brown wire of the unit, the light will stay on. However, is it possible for the unit to not go on until the motor is running and the system is charging? Why else would the switch kill black and brwn/white?
Looking at this....http://www.cmsnl.com/classic-honda-fansite/honda_wiring_diagrams/CB550.jpg
Get power for the unit from the brown/white tacho/speedo lights maybe? EDIT: Get it from brown +12v accessory. It's fused
Is that the danmoto unit? You could start connecting one thing at a time (be careful of the loose wires not to short something out). Definitely fully disconnect the turn signal indicators. That could cause some issues with LED signals. Just take it out of the equation.
That diagram shows the brown as an accessory +12v best I can tell. Comes off the tail light, goes into the fuse box, but splits to accessory. so i take back what i said about running off the brown white. run off the Brown +12v for power to the unit. It's fused.
Looks like the bridge is red(batt) to black and brown to brown/white in the On position and Red to Brown (taillight) in the P position. Unless I'm reading that wrong, I'm no expert by any means.
Stupid question, have you checked your fuses? Maybe the fuse on the red/brown going to the headlight high beam is shot.
Sorry to bombard with posts, but a big thing, check the diagram of your speedo. The green may not be ground, it could be the neutral, and black might be ground. Just double check, don't assume the wire colors are the same as honda.
Lots of information here. Thanks guys. Im still digesting over the first cup of coffee (it's raining here in SoCal so I took the morning to enjoy it and sleep in).
That's the diagram I am looking at, roflcopter. Using the brown for Head light as well... I can bridge them and use the same, which is what I think a few people are doing with this unit (yes, the dan moto unit).
PJ - its black in red to the fuses
Still questions about why there is no power to black in the second position, or why there are no lights in the first...
Look at the bottom of the diagram at the ignition switch. The first set is all the wires coming in. The second and third shows how stuff gets bridged in the different positions.
In the ON position (second block) Black to red, brown to brown/white,
in 2nd (P) position (3rd block, next to "IGNITION SWITCH" label, ONLY red to Brown.
I'm assuming 2nd position also happens during the first position otherwise brown wouldn't get power as far as I can tell.
Ah, I see what you are saying. Check this thing out, too. Made it easier for me to see:
http://oldmanhonda.com/MC/wiring500.html
So, possibly the wires are crossed/dead somewhere? Or could the switch be faulty?
oh wow thats pretty awesome.
I've actually completely confused myself because I don't understand how the brown and brown/white are getting power in the ON position... They don't bridge, only to each other, but neither is a source...
anyone? Bueller?
WAIT Now I got it.
WHen in the ON position, unless the headlight switch is closed, at the top, black to brown white, the tacho/speedo , tail, and head light won't come on. power won't go to that brown and brown/white circuit. so you won't have power during ON unless that switch is closed. only in park.
but in the on - first position - all four wires (at least in these diagrams) should fire. I get black and red power in first position but no brown/brown white. from that diagram all four should have power. TO me it means that the switch is faulty but maybe I mis-read your diagnosis in your last post. Also, I dont have a headlight switch, at least not yet.
sxecafe said:
...my mind is crunching that together. give me a sec haha.
Haha so you have danmoto power from black.
Brown and Brown/white only have power when:
A) ON position with headlight switch closed
B) P Position or p position
This makes sense. So assuming you don't need your headlight on, why would you need a taillight and speedo tach lights? (in the 70s). obviously now with how inattentive drivers are its necessary all the time.
So if there is a separate wire on the danmoto for back light, it won't come on unless that headlight switch is switched on. or if you want it on all the time, splice it to black.
Look at the top of the diagram next to the speedo lights. That headlight switch connects the black to the brown/white. and back at the switch, brown/white gives brown power. I suppose you could just slice brown/white into black somewhere and negate that switch altogether.
You can see that in the first position, black is connected to red, and brown is to br/wh, but nothing from red to brown or red to brown white like in the 2nd position. Brown doesn't get bridged until the headlight switch, looks like its on your right hand control.
Ah! Ok, so to recap (so I know i understand correctly): The problem is that the brwn/brwn-wt wont stay on all the time unless the head light switch is ON. This is because you had the option to have the head light off during the day. I was confused because I didnt have a head light switch in my set up.
Solution is to bridge everything to black, and then really have a switch for both headlight AND the back light of the danmoto if I want it on during the day or when I want to turn it on at night.
Only remaining question I have is that from what I can ascertain, Brown is the rear running light and that should be on while I'm riding no matter what time of day... but its not. Do I hardwire brwn to black to make sure running lights stay on all the time? I could still switch the head light for start up etc...
Now that you say it aloud, it gets more confusing. Because what will happen if black and brown are spliced, is you'll get power to black even in the P position. If this isn't a problem because you never use it, then I would do it.
All I can see happening in the P position is battery drain... People actually use that function?
agreed. I just wanted to point that out before telling you to do something. in case you do use it. maybe you add a switch under the seat that you just keep on all the time in place of the handlebar switch for headlight. in case of emergency, you can pop your seat and switch it offend go into park mode if you were stranded or something. up to you.
NOPE, RED live all the time
Black live with ign ON
Black OFF in P
I remember I had a similar issue, you may have to open up the switch and see if the contacts are assembled correctly
Is it a new switch?
It could be for electronic ign, they are wired differently
Good news. The switch is good... annnnnnnnnnnnnd when I bought my controls, I forgot I purchased two sets of controls. When I looked at the other set, I had a right hand control witha head light switch on it! Go figure huh? Unfortunately, I had already modified the switch I was using to fit on the bars I had so, I had to take the switch with the headlight switch on it, clean it and put it back together.
Crack 'er open:
So when I put that all back together...
Hurray!!!!!!!
