imseamless
I've already ruled out the gas cap vent and I've been through the petcock twice so I'm confident that isn't the problem. It was like the carbs we're allowing the vacuum to happen or something.Hoosier Daddy said:Sounds almost like you have two fuel problems. Might check if your vent is plugged in the fuel cap, next time it starves for fuel, try popping the cap and see if you then get fuel flow. Also there is a screen in the petcock that can plug with nasties... Blowing in the hose might might have dislodged it, or pressurized your tank if the vent is the issue, but only for a while.
Now that won't help with the fuel pissing out the vent lines once you do get it flowing. That sounds more like stuck floats or float needles not seating.
And as for the pissing gas, I was thinking the floats or needle as well. I'll dig into it in the next couple days. I appreciate the suggestions!
