"Woods" - '73 CB350F
Hoosier Daddy said:
Sounds almost like you have two fuel problems. Might check if your vent is plugged in the fuel cap, next time it starves for fuel, try popping the cap and see if you then get fuel flow. Also there is a screen in the petcock that can plug with nasties... Blowing in the hose might might have dislodged it, or pressurized your tank if the vent is the issue, but only for a while.
Now that won't help with the fuel pissing out the vent lines once you do get it flowing. That sounds more like stuck floats or float needles not seating.
I've already ruled out the gas cap vent and I've been through the petcock twice so I'm confident that isn't the problem. It was like the carbs we're allowing the vacuum to happen or something.
And as for the pissing gas, I was thinking the floats or needle as well. I'll dig into it in the next couple days. I appreciate the suggestions!
So I called the Maple Leaf repair guys and ends up they don't want to help me tune my carbs...well that is ok, I'd rather have someone be honest vs doing a shitty job just to get some cash. Got ahold of they guys at North City who specialize in vintage Hondas and the guy actually seemed excited about it and was willing to let me hang out and learn. So next Saturday we will be tuning this thing. Hopefully this week my clip-ons show up and I can complete the rest of the 'cosmetic' work.
sorry for the bum tip! if north city doesn't pan out, twinline has a dyno, but i think they're pretty expensive. good luck either way.
Re: "Woods" - '73 CB350F (More jetting fun)
Yesterday I welded up a new license plate mount because I really didn't want a ticket for the vertical one I had been running. Now it's moved behind/under the cowl and doubles as a small fender, cool! Also, after reading about how hot regulators can get, I moved mine out from the box under my seat and zip tied it on the underside of the battery tray. Cool!
For some reason, none of the above made my bike run any better ;)
Pulled the carbs and dropped the main jet down a size, as per the recommendation of friend. It ran decent for about 20 miles (with a little sputter around 5k), but I abruptly lost my top end when I was nearing that 20 mile mark. Upon giving the bike throttle, it would bog down and not climb above 5-6k. So I limped it back to the garage doing 35 in the top gear.
From my readings, "If the bike pulls harder at high rpm when cold and less hard when fully warmed up, the main jet is too large." Interesting. My bike ran a 75 main jet stock from the factory and I currently have a 85 in it. I ordered a "complete" main jet set that came with 75, 85, 90, and 95. Convenient, no 80. At this point I'm going to drop the main jet down to the factory spec of 75 and see how it does.
I also noticed once the bike is fully warmed up, my idle jumps up to about 4k. But I'm assuming I can't properly address that until the main jet is sorted.
P.S. I took photos and forgot them on the camera, then proceeded to drive 45 minutes home.
For the time being, mostly because it will cost a fortune. I'm going to make a damn good attempt to get it going, and since I still have a few ideas left I might as well exhaust them. But if I try everything I can think of and it still isn't running properly, I suppose I'll bite the bullet and take it in
Today I rejetted my mains to 75's. I timed myself, as this is about the 5th time ive pulled my carbs in the past two months, and I tore it down and built it back in 50 minutes. anyways. It started right up and I took off for a ride. I got about a block down the road and noticed it really breaking up past 6k. Ok sure, it just needs to get warmed up as the mains are smaller. sure. Got about 5 blocks down the road, ok it wont go past 6k at all. Got about 2 miles down the road and I'm coasting into a parking lot where I proceed to kick the damn thing over for 15 minutes to no avail. I ran next to it and jumped on and dropped the clutch. It sputtered and died. Kicked the shit out of it again and nothing. Called and got a ride.
Frustrated is an understatement. Buuuut, that's what I get for having an old bike and no experience, so as to be expected. Hopefully things will start moving positive soon. From here I supposed I'll rejet for the 33467534th time, this time back up a size or two as atleast it ran then.
hmmmmmm
So I also have a 350F down here in RVA. I had TONS of jetting issues when i built the bike 9 years ago. Much less info existed online back then. I wound up getting 75's and 85's and had the same problem. I ended up getting a spare set of 75's and using the ultra small drill bits to slowly make the 75's into 80ish's. i ordered the drill bits from the UK, but now you can get them at Harbor Freight. Many people will tell you this is a ghetto way to do it, but I worked great for me. I am running a 4-1 exhaust and pod filters. nothing else special. let me know if you have any questions.
BCB
your problem is either electrical or fuel flow to the carbs. jetting wont do that.
check petcock/gas tank vent for blockages
Haha. Petcock was on and I tried reserve. Carb 1 was pissing out of its overflow. I did, however, pull the brass nipple out of the petcock when trying to remove the fuel line to the carbs. So I'll need to look into that. But like I said, carbs pissing gas when petcock was on, stopped shortly after I turned the fuel off. but who knows, it could have stopped the flow for god knows what reason. I wouldn't put it past at this point
i think yuo are on the right track. clea the nipple and use soem green loctite and press it back in, see whats up w/that carb. 8)
oh.. check the fuel cap. if the vent hole is stopped up is could be causing a vapor lock and starving the bike for fuel. I sealed my tank and created one and took me a while to figure it out... Once it dawned on me, I cleared it, and never had a problem.
Will do, thanks for the advice
Nice one. Unfortunately, I've been down that road more than once and can confidently say its not the venting of the tank. I'm left with the petcock or the carbs. I need to get this crap sorted quick, the weather is getting nice and my truck is getting temperamental!
refurbishing my 350f. I'm currently running 4-1 pipes and pod filters. My bike has not yet ran since i've gotten it so im a little curious on the difficulty of jetting ;)
Easy way to test fuel delivery to the carbs: Put a transparent fuel filter on the fuel line just outside of the petcock connection, with this you can easily look down and see if there is gas in it at any time. If there's gas in it then there is fuel "head" on the carbs. You don't need a filter if your petcock filter is good, but with it you can quickly make sure you're getting gas to the carbs at any time.
You definitely have a float valve (sometimes called float needle) issue - its getting stuck open on #1 (hence the leak), it suppose that it could potentially be getting stuck closed as well (although I think that's highly unlikely). Did you replace the float valves?
Your idle jumping up to 4k is strange - what happens when you loosen the idle screw?
I totally agree on the filter; I bought one but got a size too large and it doesnt fit on my line so I'll have to get another. I also agree on the needle. It's odd though because they all seem to be free. I even flipped the carbs upside down (the way they are when on the bike) with the float bowls off and verified that all needle are dropping. So its like #1 is having an issue returning to its closed position.
I have not replaced anything in the carbs aside from the main jets.
Like m in sc said, I'm thinking that your problem may be electrical as well....which is outside of my troubleshooting experience...
Do the fuel filter to at least rule that out. $1.00 at the auto parts store.
