XS850 - Monoshock & USD Fork (pics pg 13)
Worst case scenario idea:i order parts from my yamaha classic dealer in germany,he pretty much bought all parts for RD,xs and many other models in europe.
If you need the address shoot me a message.
There is also a mikuni dealer in germany who has brand new mik brass.
Cool. Thanks for the heads up.
Hard to believe by I FINALLY got this thing out of town for a 30 mile loop on some twisty country toads. Ran well at 60mph+, and handled like a dream on the twisty's. Can't believe it took me this long to get it out there. I'll keep everyone posted on jetting round 2, and one of these days I'll remember to take a camera and get some decent photos.
While installing my new carb kits I discovered I had gas in two of my floats. Yes, the two carbs that were consistently running rich. It must have taken them a while to start filling up because I checked float level early on in the process and they were all good. Time to track down some floats. These carbs...
Thats good news!
They can be repaired as well with just a light touch of the propane torch. Well emptied of gas of course, would be unnecessary to lose an eye over this!
datadavid said:
Thats good news!
Yeah...be careful with this approach :) I use a heat gun and just slightly heat up, swish around until you find the holes. Slowly heat then back off , swish, repeat until the fuel is gone. Or just buy new floats...ha
A guy from Boise is sending me a handful of floats from a spare set of XS1100 carbs he had. I'll have to test them all before installing to make sure they don't also have holes. Assuming submersion in gas (or any fluid for that matter) for a night or two should do the trick?
Usually does. Otherwise hold uner gas/water and push in on the bulbs a little. If it's cracked you'll most likely see bubbles. Although they are tiny.
Well I got two float that appear to be floating. So that's good. Road to work with the xs1100 jet kits in the carbs today and it's definitely going to take a little more tuning now. I was so rich at idle before that it wouldn't run with the choke on, even when cold. The good news, now it does! However without the choke, it has a hard time idling. Probably going to have to richen up the air mixture. Regardless, more tuning ahead.
Great to hear about the progress, perfect is just around the corner now!
Are you running 137,5 mains now?
Have you done any top speed pulls yet?
If it idled before when rich, but won't now, why wouldn't you assume the idle mixture needs to be richer?
Ya, 137.5. The pilot is actually the same as before.
No... Just rode it to work.
Yea sorry i read it wrong! :D
Just realized and edited my post..
Just thinking, now is the time to see how it runs at full throttle in 5th.
To establish how the mains are working.
The saga of the demon carbs continues...
Double checked my fuel height, put a brand new set of plugs in, set the air mixture screws around 3 out (slight richer than stock) and ran it around the block. At idle, the #1 cylinder was popping/double firing. Rich? More on that in a minute. While riding, bike had lean symptoms. i.e. revs wouldn't drop quickly.
Checked the plugs and you'll never believe this...
#1 - RICH
#2 - OK
#3 - LEAN
WTF!? Back to where I started, but with a WHOLE LOT of changes.
Below is a comparison of what changed with the carb kits.
The stock Mk2 jets in a 79 750:
Mainjet 130
Pilot jet 42.5
Needle jet Y0
Jet Needle 5Hx6
The stock Mk2 jets in a 79 1100:
Mainjet 137.5
Pilot jet 42.5
Needle jet 266 Y-2
Jet Needle 5GZ6
I also managed to scrounge up a nearly complete set of guts from a XS1100. I know I could swap those in since there was some debate over the quality of the rebuilt kits. But at this point, I'm so baffled I don't eve think that is worth it.
Maybe time to grab one of those color tune tools huh?
Colortune is cool. Bought a kit a few months ago to check mixture on the ladys xs11, it lets you see mixture across the rev range very clearly so you can adjust accordingly
My vote is still on the triumph carbs though, just came back from a ride with mine and, man its running perfect! ;)
Hmmm...might just invest in another set of carbs :( It seems there is something quite awry with the set you have. Generally speaking they should all be just about the same on settings, with minor deviations for wearing and such. Something in this set is so far off, that I'm not sure it's worth the headache any more. Do you know anyone else that has an xs850 set of carbs you could "borrow" to see what happens?
Okay okay... stop rubbing it in! haha
Yeah, this is about where I'm at. The weather is turning anyway. Honestly I'm tempted to put it on a shelf till spring and see if I can spring for a set of Mukuni's VM's by then. Just don't have the cash for that now and I'm about to pick up another project to torture myself with over the winter. I've never given up before, but you're right, there is something seriously wrong with these carbs :(
To answer your question more directly, I don't know anybody else with a triple, at least not in these parts. A few guys about a hour away, but that's not a simple "hey let me borrow your carbs for a hour" or whatever type scenario.
Totally understand, and definitely am not calling you a quitter :) Some times old carb bodies are just done for, whether you want them to work or not. And due to the time you've put in so far, I'd say there's something off that doesn't seem to be an "easy" fix. Let us know how it goes, and if I come across any tidbits of information through doing my own work on bikes, I'll definitely bug you and see if it helps you out :)
For sure man. Wasn't calling you out for calling me a quitter. haha. Was just emphasizing the fact that this is the first time I've been defeated by a set of carbs in a long time. Especially after building an 850 last year with the Mikuni's which required almost zero turning work at all after the fact.
