Zoöid Third Times a Charm CB175
Re: Third Times a Charm CB175
Duchat said:
Even that swingarm is function and form.
yes and we get to weld chromoly to mild steel. So we have been tackling one inch at a time.
Now don't judge me too harshly for I have been TIG welding steel for two days.
Some of Zeke's welds tonight
After a few weeks practice on his TIG Zeke is almost finished with the swing arm and has started on the frame.
This morning we are making a form for the tunnel. We took a rough outside measurement.
We are using the pattern to make a hammer form out of MDF. After getting a rough outside we found the center for the top and bottom and struck a center line. We then scribed the center line and folded it in half.
finally I can see looking down
lay the pattern on the MDF and mark it.
screw two pieces MDF and cut it out with a jig saw leaving the line.
took it to the belt sander and cleaned it up to the line.
Now we sandwich a cut to fit plus 3/4"
You have to trim the ends by notching them out. Then we put it in the vice and worked our way down one side shaping the aluminum to the MDF being careful not whack too much!
next step we put it on the belt sander and made the edges even with the form. The most time consuming is the next step. You want to nurl the edges for a tight fit and you don't want any part of it to be under tension.
You can see where I need to do some more nurling. I just use a pair of pliers and a sharpie to mark how much to move the tunnel edge. Now the MDF rounded edge was measured to be the control. So as you press the bottom into the sides you have the control. You nurl the edges of the tunnel to match the sides.
simo said:
The Snake has to be gone by now... Hows thd build coming?
we reassembled the bike so that we can take it to the barber vintage festival and we had it in various stages welded. well we just got back from the Barber Vintage Festival!!! We met the Brittens! Sam Britten is a film maker and interviewed Zeke he said Victoria was "bad Osss." Saw Andrew Stroud beat Chris Boy on cold tires with the Britten!!!!! Saw 9 Brittens! Zeke road Victoria and I road Lucky around the loop road all weekend. Brian Case, the designer of the Confederete Wraith and co-founder of Motus, told Zeke that ZOÖID was perfect and not to finish it. We picked up a Kiwi helmet! Somehow I believe we're going to end up in New Zealand one day my friend.
