on board thanks!simo said:Hi Patrick thought you might be intereded in this
http://www.hondatwins.net/forums/1-project-logs/43075-turbo-honda-175-lsr-attempt.html
no illusion it is the left rear bar that we out too much heat in it. It has been fixed since then. Those are some top secret MetzlersQ said:Patrick,
Could be an illusion but it looks like forward side of the front frame is slightly offset to the right (using your blue line) ? What brand tires are those in the pictures?
Texasstar said:no illusion it is the left rear bar that we out too much heat in it. It has been fixed since then. Those are some top secret Metzlersthat are meant to make you wonder "what kind of tires are those?"
Quite the observant one you are!
close these are not marked and have trapezoids. They are part of the vintage line that Metzler is releasingQ said:Had me scratching my head, so I had to ask! I like the tire treads; didn't think to look at Metzeler's (ME11's).. nice![]()
Texasstar said:close these are not marked and have trapezoids. They are part of the vintage line that Metzler is releasing![]()
si senorsimo said:Same tread on the front?
gonna need some of your lathe wisdom!crazypj said:I thought they were some sort of 'junior' flat track tyre. tread pattern is very similar to some I had a while ago
