Zoöid Third Times a Charm CB175
We got the bungs tacked in place for the aircraft latch. Welded a small round bar for the leather for the latch. Finished mounting the forward tank mounts. Zeke made another rear set. Progress.
Looks good guys, but PLEASE do one thing for safety. Never leave the key in the chuck after removing/setting the workpiece. It hurts. Bad.
Will do! Thank you.
Q said:
ye ol Griz ... make a CB200 oil pump plunger/piston & bore/hone out a CB175 pump housing to fit... :)
i think we just pulled the oil pump and plunger off a 200 for Victoria?
Whats the purpose of the tapered front face on the cb350 plunger, would reshaping the cb200 plunger be worth while?
We got to vapor hone the engine and it is amazing! Check this out https://youtu.be/p82sUwsDq6s
i don't know I have never seen a cb350 plunger???
We split the lower end at Fullers to vapor hone it and thanks to DTT I remembered that there is a bolt inside the oil plug that needs to be removed so it was pretty easy. Just heated the Honda bond up and a couple of whacks with the dead blow it came apart.https://vimeo.com/157124466
Fuller has been working on one bike called shogun for over 8 years. Bryan had Zeke make some bushings for it on the lathe.
we also traded moms mini van for the dodge cab over
(just kidding)
