Zoöid Third Times a Charm CB175
Texasstar said:
simo can you give us the info on the closer ratio gearing for the tranny? I know you have mentioned it before
Racing - close ratio transmission; some info here (not sure if simo read your post)
http://www.novaracing.co.uk/ProductHondaCB160175CloseRatioConversionGearbox.html
Thanks guys! Simo had mentioned that link before on Victoria's string. He also said we should have used the 5th gear .96:1 from a cb200 in place of of the 1:1. He was right. We were able to wind out to 12.5k no problem in 5th on Victoria. I think we could have made a few more top end MPH.
While we have Bryan's transmission apart we are pulling a cb200 and cb160 apart for comparison. We also have an xr250r tranny coming. You never know when a motorcycle feels like it wants to be a six speed. ;) oh and all our trannies use the same oil drain pan. LOL we may have to do some surgery though and lose 10mm off the main shaft.
Next up is solving the flappy mouth politician cam chains so the slipper cam chain tensioner is on the silver tray. Zeke has been practicing welding on cast aluminum.
If your gonna go through the trouble of adding a gear (6 speed) , might as well make it a 12 speed.... :) http://www.motorcyclemuseum.org/asp/classics/bike.asp?id=123
"flappy mouth politician cam chains".... Bwhahahhahahahha :)
Sorry a little late to the party, jack seems to have covered it Always interesting watching the politicians from the other side of the world, youre ones have a longer reach than ours....
Wow that would be a blast to ride...I can imagine having a high low on my Bultaco!
i am sorry I thought hot air would rise and not go down under ;)
Here is a crack in one of the cases that has been vaporhoned and then cleaned with acetone. You can see how impregnated the case was with oil when Zeke tried to TIG the top oil started oozing out of the crack inside the case. We were told you couldn't do this so we went ahead anyways. :)
teazer said:
Engine revs x primary drive ratio x gear ratio = output sprocket revs.
Teazer you told us before that the transmission starts breaking down in the 176 once you get up over 30 hp. Some of the dogs are undercut and others are not. Is there a reason for this and it seems that going into second gear that the dogs have less to hold onto than the other gears??? I've noticed in the newer transmissions like in the 80s they used a needle bearing on the end of the countershaft and the mainshaft??? Is this primarily where the weaknesses lie?
I had the same issue with porosity when welding a cover, I ended up tigging, grinding it back then over tigging i did this 2 or 3 times till it looked clean, not sure if its the right way but it worked
I wonder what the nova gears are from?
lol what is amazing is they didn't have the internet like we do...probably a kiwi discovery checking out trannies lol
Transmissions will start to twist and bend under load and gears start to fall out. IMHO Needle roller bearings are a huge improvement over bushes but they cost more and require a hardened surface to run on.
Undercuts help to hold the gears in mesh but the harder they grab, the harder it is to change out and into the next pair, so it's always a compromise. Most transmissions have some undercuts and some gears with straight pegs/dogs. I haven't really thought that much about which need undercuts, but I would guess that lower gears would need it more than higher gears because they transmit more torque. Second and third are used more than the others, so maybe they need it more.
That makes sense. Zeke and I will go out to the shed tonight to look at the undercuts and report back. Before the quick shifters that we have today did they ever eliminate the need for neutral off of the shifter drum? Shortening the distance and time between 1 and 2 gear changes?
A few rare bikes had neutral below first to make it easy to find and as a consequence making the 1-2 shift fractionally faster.
What's a slowshifter? We use an air ram with momentary kill device for full throttle no clutch shifts on the 1/4 mile. So much faster... :-) No need to back out of the throttle at all just press teh button for almost instant gear changes.
Not so suitable on a race track or the street but can't beat them for speed.
speaking of OCDR Bill Baxter went
7.94 @ 164 in eliminations
he was so far ahead he let off!
Top Second is undercut and top 4th is undercut as it engages 5th gear
this is what the Hispeed/Akunar's look like with no base gasket. We bored piston to wall clearance to .002"
Let's see how this puppy runs with 11:1 compression. This cb160 head is serdi cut, ported and ready to run
