Build time has been down over the summer, busy with work, down but not out.
The crank was rebuilt
The condensers were connected with crusty-ass electrical tape? Connections were soldered and shrink wrapped.
Engine was closed up with ported cylinders,
Actually managed to clean all the oily gunk on and out of the oil lines, pump, bolts, etc. With no catastrophic accidents. Check valves operate as they should, which was a relief.
I will have to remove the engine side bolts however to shoot some oil down to the bearings so they are well lube for the first fire. Thats probably a ways off however.
Was going to buy some expansion chambers, but i can't really justify dropping close to 1k on a set, at least not without taking a few cracks at it myself. I grabbed some left over 20ga fired up the ol' Thunderbolt xl and had at it. (Look ma i made a funnel)
It is definitely not a pretty bead, but it should do the trick. So long as i can get the fit up spot on i can get it done without burning through, but the margin for error is slim. I may end up using some 18ga stainless for the final set of pipes. However the initial pipes will be made from regular steel, cause its cheaper practice.
