Another cb 360t, but with a sexy twist.
Remember though... When switching over to shocks made for a 500+lb bike its going to severly stiffen up the rear suspension. I prefer it that way, but it will take some time to get used to it if you've only ever ridden stock bikes with crappy soft shocks.
The RFY actually arent bad for a small bike. Several people have reworked them and had decent results with them. Others will say they are shit. To date (granted minimal use) mine have been decent after a mild rebuild and nitrogen refill (pressure match).
Gary
Mine work real well after re-build and re-gas although I used a lot more than recommended max pressure (110psi instead of 75psi)
Mine both have 100 around 100 if the nice people at my local tire discounters didn't screw me. Plenty firm and to my liking. When I received them the pressures were not even close between the two shocks.
Gary
hmmm good to know, i kept everything so far, so i still have the shocks... and re gassing them is a good idea might be an easy fix.
Although I just ran into a hindering problem with the cb 200 tank and the head bolt on my 360... the petcock hits the head bolt, I was wondering if it was possible to mount a bracket to the tank which feeds a fuel line to a valve mounted somewhere else... I haven't personally seen anybody do this on this site, however I would think its a common problem with switching tanks...
The hindering/face palm part about this is that I already had the tank professionally lined so I want to avoid drilling new holes... There is already a threaded hole to mount a screw and all I think I need is a bracket that will fit with an O-ring with a tube or something to guide the fuel to the valve... What do you guys think?
I've already tried lifting the tank in the back to see if I can get clearance... but it has to be lifted so high that it will look pretty funky...
Here is some pics first is the original petcock
second is the petcock but fortunately found out that an old cb350 petcock bowl has the same thread as the cb200 and tried that... but still doesn't clear
No reason why you couldn't design a simple bolt on 90 degree angled barb and connect that to a remote on-off petcock from any agricultural equipment. We use a snowmobile one on the auxiliary test tank, and it flows more than enough. Just make sure you can get to it in case it has to be shut off.
Signed on, keep it up.
Second on the 90 and separate valve.
Sent from my Galaxy Nexus using Tapatalk 2
You did try relocating front mount to move tank back an inch or so?
neevo had to do something similar with his CB400f
There are a few bikes that used remote tap, some Suzuki Intruder 800's, early GSX-R, I think GSX550 (late 80's)
Making a new outlet shouldn't be a massive PITA
Had a disscussion like this a while back when I was going to use a 200 tank on a 450.
Why not just make an adapter plate sorta like this
and mount a right angle valve sorta like this one.
Doesn't hang down near as much and since the 200 petcock bolts on you should be able to make just the plate you need.
Problem with the 200 single bolt is it bolts inside the filter bowl to keep pressure more or less even on 'O' ring seal
An offset single bolt leaks
Then make an adapter with a single tube coming off, run fuel line and a shut of there. DOUBT very seriously that it will leak unless something is warped or over tightened.
Use one of these
