ex119x said:I agree that the swingarm angle is just all wrong. Before I went any farther I would put a shorter shock in there. Look at a CBR900RR shock as it has a remote reservoir so it should give you the clearance you need. You could also look at the shock off a 650 Ninja since it is a non-linkage set up. How about making up an adjustable strut out of a turnbuckle and start making it shorter until you get the swingarm into the 10* range. Then you can find a shock that matches that length.
I like the Ascot tank on there. Looks good.
Tune-A-Fish© said:You likely have a 100> pounds of spring weight to add, toss some sand bags or equal on and see how close that ass is setting at wet.
Sure! From what I've taken I need to.be in the 12in wide and about 8-9ish tall area. If there is something readily available I'll sure use it.irk miller said:Have you looked at a GL1000 radiator? It's center mounted and single unit, although the frame is configured so the rad fits inset to the frame. I can get a measurement, if you want to look.
hurco550 said:Loving this thing. Fun fact, bucyrus is just up the road from me. There is Alot of Marion power shovel/ bucyrus Erie heritage around here. Nice work my friend
