If you have a functioning solution for the same style front end caliper mount, then show him some pics. I'd like to see to, because when I've tried this before I couldn't find a solution.cxman said:mine is a 04 gsxr front end?
Damn that sucks man. I think I warned you about this a few pages back. I don't think you can sand that much off the caliper to make it work. There was a build thread where someone cut down his calipers with success, I'll try to find it. I'm not recommending that but hey if it works in combination with sanding down the ribs on the comstars then good. I knew some of the comstars had changed so I'm glad you double checked everything. It looks like you have dual caliper comstars even if the setup was only one when you got it. Mine is a single caliper rim which would account for the differences.rs_ss350 said:Actually... the rims are too wide for the calipers... what can be done about this? One of the early posts in this thread shows a comstar with these calipers. Can i swap the forks to pull the calipers out a little? Or anything else can be done?
Thanks!
erock85 said:Damn that sucks man.
cxman said:ok i dont know the answers to all that i have not done that much research
that was the first one i did
i have used a few other ones of the same vintage
i have used a couple of busa front ends and some cbr ones
i use the same set up with the same comstar wheel and it all works
i only had ot figure out the dimensions once and the guy i get to do the adapters just makes them now
if there are particulars you want i can measure them for you off the bike
irk miller said:You don't really need the dust seals. It has sealed bearings.
