rs_ss350
Active Member
cxman said:i used a 82 gl1100 wheel what did you use?
82 CB750
Streetfighterkz said:Also if you need more diameter than 320mm disk, the CBR929/954 use 330mm rotors, I believe.
Im thinking 10mm, 330-310=20/2=10rs_ss350 said:Would it be advisable to go that route? If so, what size would the caliper spacers need to be? 15mm?
erock85 said:Im thinking 10mm, 330-310=20/2=10
Assuming your measurements are correct, that seems to work out mathematically.rs_ss350 said:Thanks! In the meantime I'd like to get my axle spacers ordered up... so considering the 153mm fork width, 64.5mm inner collar, 2x9mm bearings, and built in 13mm spacer on the left side of the axle, I get 35.25 on the right spacer, and 22.25 on the left... does that sound right?
erock85 said:Assuming your measurements are correct, that seems to work out mathematically.
Draftsight for 2D sketches and Solidworks for 3D modelingrs_ss350 said:Thank you. Btw, what program is that you are using?
rs_ss350 said:Whoa cool. You're using the original axle. Are you not finding any issues with the calipers coming into contact within the rim? Those rims don't quite look like mine from what I can tell. Can you zoom out on the rim?
focusinprogress said:I'm guessing you have the later ones where they flipped the spokes and they're black with the edges curved outward instead of inward? that's where the clearance issue differs.
irk miller said:Hmm. I did a VZ800 on a GL too, but used spoke rims and Henry Abes.
Untitled by nicholas edsell, on Flickr
