Drivable scaled Ferrari 312pb
Lol! Here is another one, I don't even have a sheet metal brake! I really should have invested in some tools before I started. To late now.
Yep, better invest in a cape and a mask! My hat's (and helmet) off to ya!
It's off while I finish the frame. Front finished,gas tanks mounted and one lower side done
Is all the front-end steering and suspension linkage from the same ATV as the rear-end ? The sheet metal looks great man
Thanks! No front is a classic Austin mini 7.5 front disc and hub and a arms are golf cart that I modified to work with Austin ball joint hub
Nothing short of a work of art! As excited as I am to see the body, I hope it can be easily removed to show all of your fabrication work as well!
Thanks guys! Hurco yes body work will be easy on easy off. when the frame was done I said to myself it's a shame to cover this up in aluminum, Now I'm saying man it's a shame to cover up the aluminum! Hopefully the body work will be the.same way.
The engine on that thing just gets me. It is perfect. It's going to sound absolutely rabid and the power:weight is going to be bonkers. Did you start with a set of welding prints or layout sheet or anything when beginning your design and mock-up ?
