as always we give u Summa cum laudeteazer said:Stock CB200 seals are fine. In fact we fit 200 guides and seals in our sloper motors too.
Teazer can you expound on what you meant on "blade type"? We got the cbr600 cam chain tensioner in the mail today."teazer said:Hold off on the tensioner bolt fix until you have had a chance to work out a new blade type solution because that may require a different adjuster.
So this would be the on seat pressure. What would be the full lift pressure for .40" lift? ).270 * 1.5teazer said:Don't put a foot in it. Force is measured in pounds and Kg - no feet or metres (or meters) and it appears to be measured at the compressed/fitted length of 30mm. The second line appears to be the same data in pounds and inches. So the total compressed load would be around 17Kgm
we are Dutch!!!Bert Jan said:whahaha i used a dremel with extension cord and the sanding thingies on the rubber roll aswell. And i used the Hansen website for reference hahaha great minds think alike![]()
talley ho sir Teazer!teazer said:I think he meant that measuring a spring on the bench out of the engine, they were all shorter than Honda's spec's. The way that installed height is adjusted is with shims or machining the spring seat area. If you sink the valves back into the head, the spring height will be higher than stock and if necessary you can slip some shims under the spring seats.
I had a bunch of them machined at different thicknesses for a CB77 racer but haven't needed to on the 160/175/200 heads so far.
Tappet adjusting screw is there to adjust valve running clearances and does nothing for spring height.
Not so sure about your missing family joules but Crown joules are created on top of the piston...![]()
teazer said:Center pin is not pinned or splined. It's a press fit and has to be correctly indexed. Rod length, pin diameter etc I'll have to look up.
kopcicle said:so aside from the camshaft modifications an easy rephase ......
~kop
