This should be interesting. Air Fuel should be better but that doesn't necessarily mean a lot more power unfortunately. There should be a couple of ponies in there though.
Oh just for grins we set our float height at 21mm from the top of the float to the edge of the lip just like the manual says and filled the carbs bowls to check the level...not enough fuel compared to how we set Lucky's 18 mm carbs. We measured it to the base below the gasket...it is 18mm to the edge and 20mm to the base...don't plan on having another lean condition :) we also pulled the tank screen and installed inline filters. Also when you measure it make sure the float is just touching the float valve and not pressing it in.
Nebr_Rex said:
Go! Mikuni, Go!
the Mikuni's are oh so sexy with those "cute" polini stacks. But my money is on the Keihins...two reasons. Velocity and the cb750 stacks..giving our overall intake a longer length...and I am sentimental to how we found the cb750 velocity stacks.
Now if you look at the Mikunis vm20 vs vm 22 you will see some similarities with what honda did to the 18mm and 20mm keihin. Now the only difference between the 18mm keihin and the 20mm keihin is the air jet...everything else is the same.
Teazer has opened up a whole world of carb possibilities to us...and Kop has privately shared some dark black magic carb tricks with us...we are sworn to secrecy or we are turned into ...and we now have the extra parts to modify ;)
We wonder what happens if you remove the air jet from the 20mm Mikuni...voila increased top end just like the Honda...without buying another carb. You will see in the parts fiche that the Mikuni vm22 has no air jet in it. So all we have to do is swap out needles, floats, air valves ... And by that time we can buy 4 mikuni vm22's or we can remove the air jet from the Mikuni's and see what happens on the dyno. I think the mikunis will have a better torque curve with the polini stacks and the keihins will produce more top end HP...because of the cb750 velocity stacks.
dyno duel and the winner is....megacycle cam
32 is the mikuni
28 is the keihin
20mm Keihin left and right 89 octane 90 jets
Dynojet Research Inc.
Run Name: G:\RunFile_028.drf
Run Title: 20mm keihin right side
Run Notes:
Run Date: 10/2/2013 4:24:44 PM
4th gear
RunFile_028.drf: 90.76 °F 29.64 in-Hg Humidity: 32 % STD: 1.04 Average Gear Ratio: 132.89
s RPM x1000 hp ft-lbs Air/Fuel
0.30 4.00 N/A N/A 10.21
0.63 4.10 5.57 7.13 10.00
0.88 4.20 6.35 7.94 10.71
1.14 4.30 7.04 8.60 12.10
1.41 4.40 7.40 8.84 14.03
1.63 4.50 7.75 9.05 13.28
1.88 4.60 8.08 9.22 12.73
2.12 4.70 8.22 9.18 11.61
2.36 4.80 8.51 9.31 10.76
2.61 4.90 8.79 9.43 10.08
2.83 5.00 9.06 9.52 10.20
3.07 5.10 9.33 9.61 10.30
3.31 5.20 9.43 9.53 10.38
3.54 5.30 9.67 9.59 10.26
3.78 5.40 9.86 9.59 10.64
4.00 5.50 10.31 9.84 11.28
4.23 5.60 10.60 9.94 11.39
4.45 5.70 10.78 9.93 11.25
4.68 5.80 11.12 10.07 11.49
4.91 5.90 11.27 10.03 11.72
5.12 6.00 11.65 10.20 12.01
5.35 6.10 12.00 10.33 12.11
5.56 6.20 12.23 10.36 11.75
5.78 6.30 12.55 10.46 12.14
6.00 6.40 12.77 10.48 12.83
6.22 6.50 12.91 10.43 12.90
6.44 6.60 13.10 10.42 12.71
6.67 6.70 13.24 10.38 12.51
6.89 6.80 13.37 10.33 12.38
7.12 6.90 13.49 10.27 12.46
7.34 7.00 13.71 10.29 12.64
7.57 7.10 14.00 10.35 12.41
7.79 7.20 14.16 10.33 12.44
8.02 7.30 14.38 10.35 13.31
8.24 7.40 14.57 10.34 13.12
8.48 7.50 14.74 10.32 13.38
8.70 7.60 14.98 10.35 13.08
8.93 7.70 15.04 10.26 12.97
9.17 7.80 15.14 10.19 13.11
9.40 7.90 15.31 10.18 13.17
9.64 8.00 15.40 10.11 13.26
9.89 8.10 15.38 9.97 13.29
10.13 8.20 15.43 9.88 12.87
10.39 8.30 15.42 9.76 12.57
10.63 8.40 15.68 9.80 12.76
10.89 8.50 15.51 9.59 12.83
11.14 8.60 15.80 9.65 13.06
11.41 8.70 15.91 9.60 13.19
11.68 8.80 15.86 9.47 12.89
11.94 8.90 15.68 9.25 13.01
12.23 9.00 15.73 9.18 12.31
12.50 9.10 15.85 9.15 12.77
12.80 9.20 15.69 8.96 12.28
13.08 9.30 15.65 8.84 12.70
13.38 9.40 15.78 8.82 12.98
13.68 9.50 15.54 8.59 12.96
14.00 9.60 15.43 8.44 13.20
14.31 9.70 15.57 8.43 12.78
14.64 9.80 15.36 8.23 12.86
14.98 9.90 15.18 8.05 12.71
15.32 10.00 15.25 8.01 13.19
15.68 10.10 14.70 7.64 12.67
16.04 10.20 14.77 7.61 12.67
16.43 10.30 14.33 7.31 12.45
16.81 10.40 14.24 7.19 11.99
17.24 10.50 14.08 7.04 11.42
17.66 10.60 13.61 6.74 12.37
18.11 10.70 13.46 6.60 12.24
MAX: 18.11 10.70 15.91 10.48 14.03
MIN: 0.30 4.00 5.57 6.60 10.00
Run Name: G:\RunFile_029.drf
Run Title: 20mm keihin leftside
Run Notes:
Run Date: 10/2/2013 4:24:52 PM
RunFile_029.drf: 91.00 °F 29.64 in-Hg Humidity: 31 % STD: 1.04 Average Gear Ratio: 133.04
0.44 4.20 7.05 8.81 11.76
0.70 4.30 7.24 8.85 12.98
0.94 4.40 7.67 9.15 13.69
1.17 4.50 7.89 9.21 12.56
1.44 4.60 8.04 9.18 12.30
1.67 4.70 8.20 9.17 12.53
1.92 4.80 8.38 9.17 11.26
2.16 4.90 8.70 9.32 11.02
2.38 5.00 9.06 9.51 11.44
2.64 5.10 9.17 9.44 10.91
2.88 5.20 9.28 9.37 10.85
3.12 5.30 9.68 9.59 10.71
3.35 5.40 9.93 9.66 10.23
3.56 5.50 10.21 9.75 N/A
3.80 5.60 10.65 9.99 11.41
4.02 5.70 10.80 9.96 10.68
4.25 5.80 11.27 10.21 11.72
4.47 5.90 11.47 10.21 12.00
4.68 6.00 11.76 10.30 11.89
4.91 6.10 12.08 10.40 11.68
5.12 6.20 12.20 10.33 11.80
5.35 6.30 12.49 10.41 11.87
5.56 6.40 12.74 10.45 11.92
5.78 6.50 12.92 10.44 12.24
6.01 6.60 13.03 10.37 12.64
6.23 6.70 13.33 10.45 12.99
6.45 6.80 13.31 10.28 12.38
6.69 6.90 13.48 10.26 12.16
6.90 7.00 13.70 10.28 12.89
7.14 7.10 14.00 10.35 12.93
7.35 7.20 14.27 10.41 13.02
7.58 7.30 14.36 10.33 13.17
7.80 7.40 14.56 10.33 12.62
8.04 7.50 14.77 10.34 12.70
8.27 7.60 15.00 10.37 12.41
8.49 7.70 15.16 10.34 12.55
8.73 7.80 15.18 10.22 12.36
8.96 7.90 15.23 10.12 12.92
9.21 8.00 15.25 10.01 12.45
9.45 8.10 15.42 10.00 13.08
9.69 8.20 15.53 9.95 12.76
9.94 8.30 15.50 9.81 13.07
10.20 8.40 15.66 9.79 13.21
10.44 8.50 15.81 9.77 12.65
10.71 8.60 15.76 9.63 12.76
10.96 8.70 16.05 9.69 12.78
11.24 8.80 15.96 9.52 12.65
11.49 8.90 15.81 9.33 12.77
11.77 9.00 16.03 9.35 12.83
12.05 9.10 15.80 9.12 12.97
12.34 9.20 15.80 9.02 12.92
12.63 9.30 15.77 8.91 12.59
12.92 9.40 15.89 8.88 12.58
13.23 9.50 15.64 8.65 12.70
13.55 9.60 15.58 8.52 12.40
13.87 9.70 15.56 8.42 12.49
14.18 9.80 15.50 8.31 12.62
14.52 9.90 15.33 8.13 12.43
14.86 10.00 15.29 8.03 12.49
15.20 10.10 15.12 7.86 12.70
15.58 10.20 14.72 7.58 12.75
15.94 10.30 14.79 7.54 12.67
16.35 10.40 14.39 7.27 N/A
MAX: 16.35 10.40 16.05 10.45 13.69
MIN: 0.44 4.20 7.05 7.27 10.23
mikuni's 130 jet after porting petcock...running rich
Run Name: G:\RunFile_032.drf
Run Title: right mikuni 130 jet
Run Notes:
Run Date: 10/2/2013 4:25:02 PM
RunFile_032.drf: 92.86 °F 29.63 in-Hg Humidity: 28 % STD: 1.04 Average Gear Ratio: 132.25
0.74 5.40 4.61 4.48 14.62
0.96 5.50 8.60 8.21 12.60
1.18 5.60 10.10 9.47 12.47
1.40 5.70 10.89 10.03 12.86
1.62 5.80 11.11 10.06 12.82
1.84 5.90 11.37 10.12 12.66
2.08 6.00 11.66 10.20 12.26
2.29 6.10 11.80 10.16 11.84
2.52 6.20 12.15 10.30 11.36
2.73 6.30 12.41 10.35 11.15
2.96 6.40 12.57 10.32 11.04
3.18 6.50 12.80 10.35 10.57
3.42 6.60 12.86 10.24 10.02
3.64 6.70 13.06 10.24 10.39
3.87 6.80 13.20 10.19 10.38
4.09 6.90 13.43 10.22 10.08
4.33 7.00 13.62 10.22 10.00
4.55 7.10 13.77 10.19 10.00
4.79 7.20 13.94 10.17 10.05
5.02 7.30 14.00 10.07 10.17
5.26 7.40 14.15 10.04 N/A
5.50 7.50 14.34 10.04 10.00
5.73 7.60 14.51 10.03 10.00
5.97 7.70 14.65 9.99 10.00
6.22 7.80 14.63 9.85 10.00
6.46 7.90 14.87 9.89 10.00
6.71 8.00 14.96 9.82 10.00
6.94 8.10 15.23 9.87 10.04
7.20 8.20 15.38 9.85 10.35
7.44 8.30 15.59 9.87 10.20
7.68 8.40 15.82 9.89 10.03
7.93 8.50 16.05 9.92 10.76
8.19 8.60 16.17 9.88 11.23
8.43 8.70 16.42 9.91 11.28
8.69 8.80 16.36 9.77 11.31
8.96 8.90 16.24 9.59 N/A
9.23 9.00 16.18 9.44 10.51
9.50 9.10 16.32 9.42 11.54
9.77 9.20 16.32 9.32 11.26
10.06 9.30 16.01 9.04 11.21
10.35 9.40 15.98 8.93 11.35
10.64 9.50 16.03 8.86 10.68
10.95 9.60 15.96 8.73 11.16
11.26 9.70 15.68 8.49 11.22
11.57 9.80 15.91 8.53 11.32
11.89 9.90 15.82 8.39 11.47
12.22 10.00 15.83 8.32 11.53
12.54 10.10 15.92 8.28 12.04
12.89 10.20 15.57 8.02 11.84
13.24 10.30 15.33 7.82 11.57
13.61 10.40 15.34 7.75 11.34
13.98 10.50 15.08 7.54 10.61
14.38 10.60 14.81 7.34 N/A
14.76 10.70 14.82 7.27 10.79
15.16 10.80 14.82 7.21 11.84
15.58 10.90 14.68 7.07 12.19
16.06 11.00 13.66 6.52 12.14
16.53 11.10 13.57 6.42 N/A
MAX: 16.53 11.10 16.42 10.35 14.62
MIN: 0.74 5.40 4.61 4.48 10.00
left right Mikuni 140 jets
Run Name: G:\RunFile_030.drf
Run Title: left mikuni
Run Notes:
Run Date: 10/2/2013 4:24:56 PM
RunFile_030.drf: 92.11 °F 29.63 in-Hg Humidity: 29 % STD: 1.04 Average Gear Ratio: 132.88
0.28 5.10 7.37 7.59 14.59
0.51 5.20 9.34 9.44 14.54
0.73 5.30 9.53 9.44 13.48
0.98 5.40 9.87 9.60 11.51
1.19 5.50 10.06 9.60 10.60
1.43 5.60 10.38 9.73 10.58
1.66 5.70 10.68 9.84 10.87
1.89 5.80 10.72 9.71 10.55
2.13 5.90 10.93 9.73 10.00
2.36 6.00 11.24 9.84 10.00
2.59 6.10 11.41 9.83 10.00
2.82 6.20 11.63 9.85 10.00
3.06 6.30 11.82 9.85 10.00
3.28 6.40 12.04 9.88 10.00
3.53 6.50 12.17 9.83 10.00
3.76 6.60 12.32 9.80 10.00
4.00 6.70 12.56 9.84 10.00
4.23 6.80 12.74 9.84 10.00
4.48 6.90 12.87 9.79 10.00
4.71 7.00 13.15 9.86 10.00
4.95 7.10 13.31 9.84 10.00
5.20 7.20 13.42 9.79 10.00
5.43 7.30 13.71 9.86 10.00
5.67 7.40 13.81 9.80 10.00
5.91 7.50 13.84 9.69 10.00
6.16 7.60 14.00 9.68 10.00
6.43 7.70 13.83 9.44 10.00
6.67 7.80 14.15 9.53 10.00
6.92 7.90 14.29 9.50 10.00
7.17 8.00 14.60 9.59 10.00
7.41 8.10 14.95 9.69 10.00
7.66 8.20 15.27 9.78 10.00
7.91 8.30 15.36 9.72 10.00
8.16 8.40 15.59 9.75 10.00
8.42 8.50 15.59 9.63 10.04
8.67 8.60 15.97 9.76 10.61
8.93 8.70 15.81 9.55 10.34
9.21 8.80 15.80 9.43 10.00
9.47 8.90 15.92 9.40 10.00
9.75 9.00 15.78 9.21 10.00
10.03 9.10 15.80 9.12 10.00
10.32 9.20 15.66 8.94 10.00
10.61 9.30 15.73 8.88 10.00
10.92 9.40 15.45 8.63 10.00
11.22 9.50 15.35 8.48 10.00
11.55 9.60 15.20 8.32 10.00
11.87 9.70 15.27 8.27 10.00
12.20 9.80 15.06 8.07 10.00
12.54 9.90 14.94 7.92 10.00
12.87 10.00 15.12 7.94 10.00
13.23 10.10 14.95 7.77 10.00
13.58 10.20 15.13 7.79 10.00
13.95 10.30 14.96 7.63 10.00
14.31 10.40 15.10 7.62 10.00
14.70 10.50 14.78 7.39 10.01
15.10 10.60 14.61 7.24 N/A
MAX: 15.10 10.60 15.97 9.88 14.59
MIN: 0.28 5.10 7.37 7.24 10.00
Run Name: G:\RunFile_031.drf
Run Notes:
Run Date: 10/2/2013 4:24:58 PM
RunFile_031.drf: 92.48 °F 29.64 in-Hg Humidity: 28 % STD: 1.04 Average Gear Ratio: 132.10
0.28 5.30 6.00 5.94 N/A
0.46 5.40 9.53 9.27 10.48
0.71 5.50 9.97 9.52 10.08
0.93 5.60 10.29 9.65 10.08
1.16 5.70 10.58 9.75 10.69
1.40 5.80 10.83 9.81 10.30
1.61 5.90 11.12 9.90 10.26
1.86 6.00 11.30 9.89 10.56
2.08 6.10 11.44 9.85 10.39
2.32 6.20 11.79 9.99 10.17
2.54 6.30 12.06 10.06 10.01
2.78 6.40 12.22 10.03 10.00
3.00 6.50 12.40 10.02 10.00
3.24 6.60 12.61 10.03 10.00
3.46 6.70 12.73 9.98 10.00
3.71 6.80 12.97 10.02 10.00
3.93 6.90 13.15 10.01 10.00
4.17 7.00 13.44 10.08 10.00
4.39 7.10 13.62 10.08 10.00
4.64 7.20 13.67 9.97 10.00
4.88 7.30 13.71 9.86 10.00
5.11 7.40 14.09 10.00 10.00
5.36 7.50 14.09 9.87 10.00
5.60 7.60 14.19 9.81 10.00
5.85 7.70 14.37 9.80 10.00
6.09 7.80 14.45 9.73 10.00
6.34 7.90 14.63 9.72 10.00
6.60 8.00 14.66 9.62 10.00
6.84 8.10 14.92 9.68 10.00
7.09 8.20 15.10 9.67 10.00
7.34 8.30 15.46 9.78 10.00
7.59 8.40 15.63 9.77 10.10
7.83 8.50 15.79 9.76 10.15
8.10 8.60 15.92 9.72 10.19
8.35 8.70 16.03 9.67 10.38
8.62 8.80 15.96 9.52 10.18
8.87 8.90 15.93 9.40 10.53
9.16 9.00 15.66 9.14 10.37
9.45 9.10 15.62 9.01 10.09
9.74 9.20 15.69 8.96 10.57
10.03 9.30 15.67 8.85 N/A
10.34 9.40 15.39 8.60 10.24
10.64 9.50 15.55 8.60 10.00
10.95 9.60 15.55 8.51 10.00
11.30 9.70 15.03 8.14 10.00
11.61 9.80 15.61 8.37 10.00
11.94 9.90 15.41 8.17 10.00
12.30 10.00 14.98 7.87 10.00
12.65 10.10 15.20 7.90 10.00
12.99 10.20 15.08 7.76 11.09
13.36 10.30 15.08 7.69 11.08
13.72 10.40 15.08 7.62 11.18
14.09 10.50 15.10 7.55 11.42
14.49 10.60 14.92 7.39 11.70
14.88 10.70 14.30 7.02 12.12
15.29 10.80 14.80 7.20 12.20
15.75 10.90 13.99 6.74 12.47
16.18 11.00 14.06 6.71 11.44
16.66 11.10 13.63 6.45 11.54
17.24 11.20 12.37 5.80 13.42
MAX: 17.24 11.20 16.03 10.08 13.42
MIN: 0.28 5.30 6.00 5.80 10.00
mikuni 125 jets
Run Name: G:\RunFile_035.drf
Run Notes:
Run Date: 10/2/2013 4:25:10 PM
RunFile_035.drf: 94.21 °F 29.63 in-Hg Humidity: 27 % STD: 1.04 Average Gear Ratio: 131.81
0.31 6.20 11.15 9.45 13.96
0.54 6.30 12.19 10.16 13.34
0.76 6.40 12.40 10.18 12.70
0.99 6.50 12.63 10.20 12.25
1.21 6.60 12.82 10.20 11.58
1.45 6.70 13.03 10.22 11.48
1.67 6.80 13.23 10.22 11.33
1.90 6.90 13.46 10.25 11.41
2.13 7.00 13.56 10.18 11.66
2.37 7.10 13.85 10.25 11.27
2.60 7.20 13.96 10.18 11.30
2.83 7.30 14.09 10.14 11.61
3.07 7.40 14.26 10.12 11.11
3.30 7.50 14.37 10.07 10.60
3.56 7.60 14.32 9.89 10.14
3.79 7.70 14.57 9.94 10.01
4.04 7.80 14.64 9.86 10.00
4.29 7.90 14.75 9.81 10.00
4.52 8.00 14.92 9.79 10.14
4.78 8.10 15.23 9.88 10.44
5.03 8.20 15.35 9.83 10.04
5.27 8.30 15.63 9.89 10.00
5.52 8.40 15.88 9.93 10.07
5.78 8.50 15.90 9.82 10.10
6.02 8.60 16.09 9.83 10.95
6.27 8.70 16.27 9.82 10.81
6.54 8.80 16.36 9.76 11.25
6.80 8.90 16.27 9.60 11.44
7.08 9.00 16.24 9.48 11.38
7.35 9.10 16.08 9.28 11.16
7.62 9.20 16.35 9.33 10.98
7.91 9.30 16.07 9.08 10.65
8.22 9.40 15.72 8.78 10.77
8.52 9.50 15.80 8.74 10.24
8.84 9.60 15.62 8.55 10.35
9.13 9.70 15.85 8.58 10.73
9.47 9.80 15.60 8.36 10.26
9.81 9.90 15.52 8.23 10.54
10.13 10.00 15.37 8.07 10.91
10.46 10.10 15.70 8.16 11.71
10.82 10.20 15.17 7.81 11.49
11.23 10.30 14.18 7.23 11.81
11.63 10.40 14.29 7.22 11.53
12.01 10.50 14.46 7.23 11.58
12.44 10.60 14.11 6.99 12.35
12.87 10.70 14.01 6.88 12.97
13.31 10.80 14.29 6.95 13.15
13.75 10.90 14.08 6.78 13.83
14.31 11.00 12.41 5.92 12.61
MAX: 14.31 11.00 16.36 10.25 13.96
MIN: 0.31 6.20 11.15 5.92 10.00
Looks like the Keihins were slightly better up to around 62 MPH or so and then the Mik's edged out in front but they still go lean as revs rise above 9.5-10k.
That's above the peak at just under 9k but might stretch the power further after the peak.
I would see if you can get the float valve seats opened up to 2.0mm. If you drill it at home, the hole will not be very round because it really needs a different rake angle on the drill bit for brass to avoid it digging in.
When it's apart for a cam, try to shorten and lighten those big heavy pistons. Our 180cc motor peaks at around 11,250 with super light, short pistons that have also been "cammed" - in other words we remove metal from the sides of the pistons to make them more oval to reduce viscous drag.
With those stock heavy thick piston rings it will probably peak at around 10k or so with a decent street type cam, but I would expect it to lift the peak by 4-5hp on that motor.
thanks Teazer... no doubt we are not taking advantage of intake flow. Both carbs flow 42cfm. Both carbs said at 9k..."listen to Teazer and buy the damn cam" She runs great with the keihins cold and after the mikunis are warmed up...just as well. We had a heck of a lean condition with the flow restriction. I suspect we can mimic the 17.3 HP we got by jetting down...What was amazing was the 20mm keihins went slightly rich at the end just like the 18's. Good Honda engineering or our floats set too low?
Would it help the mikunis to also go with an adjustable float like the keihins? These have the plastic floats and not the brass. I think they are fixed.
The other mods you suggested have made a staggering difference in performance. We are going to the lighter pistons after barber. We will shed 68 g per piston and put the new valve springs and titanium retainers from R/D which will shed another 10g each.
So our restricted petcock gave us the best Dyno insight...there is something deep and meaningful to that statement.
Why is 13 the magic fuel number. At 9900 rpm we produced good hp on all Dyno runs. We produced our max hp when we were at 13 on the fuel number.
This first pick is the restricted petcock runs.
The second pick is from yesterday's runs.
people think that they are looking for 14.7 or Lambda=1, and that's true for complete combustion in a perfect world. In reality most engines make best power closer to 13:1. I believe the answer lies in the incomplete combustion. All the air and fuel is not typically used up. Some O2 and some fuel go down the pipe. So teh answer is to give the motor enough fuel so that all the oxygen is burned. That will give max power. That's what limits power the amount of oxygen that is burned.
In the case of those Mikunis, I would look at the float valves because that is most likely to be the fuel restriction and that means the float bowls slowly empty.
On the Keihins, that slightly rich top end is probably deliberate to keep the motor cooled with excess fuel. If you pull out the air jets and replace them with some a poofteenth smaller, you can tweak that fuel curve and flatten it, but I'd leave them be. We had a bunch of air jets machined when we were messing on the dyno looking for perfection and on the track the difference was so small to make no difference.
I don't recall where that image came from originally, but I just found it reposted at http://www.motoiq.com/MagazineArticles/ID/1631/PageID/2199/Suck-Squish-Bang-Blow-part-3-Compression-Ratio-and-Air-Fuel-Ratio.aspx
That's a relief. :-) It's not as if this is public or anything. And the interwebs thing is secure right?
Now to find time to port that poor little CB160 head that's sitting on the bench. Poor thing has no idea what unpleasantness it is headed for. And then I need to send another cam off to Megacycle. I'll have to dig out the lift curve charts to get one with minimal overlap so the valves don't tangle, but reasonable duration to make the most of the poor port flows.
Pretty important thing right there. I don't think Megacam was expecting me to run +1mm on my valves when I bought their cam for the 360. It's a little close for comfort. If I get my lash wrong, there will be sad times in Oregon.
Just get the valves sunk back slightly into the seats and give that recess a good radius. If you have to go too deep, the springs may need to be shimmed which is rather like the deer/honda interface thread. Every action has a consequence.
Already been down that route. Not much metal left in this head for playing... I should have just done the exhaust valves, methinks. You live, you learn. :)
