the Mikuni's are oh so sexy with those "cute" polini stacks. But my money is on the Keihins...two reasons. Velocity and the cb750 stacks..giving our overall intake a longer length...and I am sentimental to how we found the cb750 velocity stacks.Nebr_Rex said:Go! Mikuni, Go!
thanks Teazer... no doubt we are not taking advantage of intake flow. Both carbs flow 42cfm. Both carbs said at 9k..."listen to Teazer and buy the damn cam" She runs great with the keihins cold and after the mikunis are warmed up...just as well. We had a heck of a lean condition with the flow restriction. I suspect we can mimic the 17.3 HP we got by jetting down...What was amazing was the 20mm keihins went slightly rich at the end just like the 18's. Good Honda engineering or our floats set too low?teazer said:Looks like the Keihins were slightly better up to around 62 MPH or so and then the Mik's edged out in front but they still go lean as revs rise above 9.5-10k.
That's above the peak at just under 9k but might stretch the power further after the peak.
I would see if you can get the float valve seats opened up to 2.0mm. If you drill it at home, the hole will not be very round because it really needs a different rake angle on the drill bit for brass to avoid it digging in.
When it's apart for a cam, try to shorten and lighten those big heavy pistons. Our 180cc motor peaks at around 11,250 with super light, short pistons that have also been "cammed" - in other words we remove metal from the sides of the pistons to make them more oval to reduce viscous drag.
With those stock heavy thick piston rings it will probably peak at around 10k or so with a decent street type cam, but I would expect it to lift the peak by 4-5hp on that motor.
teazer said:I'll have to dig out the lift curve charts to get one with minimal overlap so the valves don't tangle, but reasonable duration to make the most of the poor port flows.
