So I looked up sr taper bearing swaps and found out it was good to go I took that old rubber gasket threw that under the new shit to fill that gap in and everything is bolted up!! The old bearing cups and gasket say flush to the bottom but the new one is magical and doesn't go as low... I started to assemble the forks with the new seals and I'll be getting fork oil for them on the way home tomorrow gonna try out the suggested 10wt. I removed all the extra spacers and a little spring that measures about .8 inch. The suggested spacer for the springs I have is .75 inch not sure about the geometry of this whole thing so I don't know if I should use a spacer or not the rear shocks are 13" which is a half in longer than stock. And I can get the measurements of the tires... Fuck this is a long post... Next up is getting the triples and forks together and the front wheel cleaned, painted, and the new bearings put in
Phone died not a lot of pics this time
