Re: "Patina" The 1973 CB175 Cafe Racer
You have the yellow wired into the wrong side it goes on the right of the dyna
Now all you need is to wire a hot to the left side of the dyna coil and you will be golden
Ok. So I'm still missing a power wire though right? To the left side? And then move the kill to the left?
You are missing power to the left side of you coil where you have the yellow wire in your picture
Ok, from the instructions I need to have the yellow and power on opposite sides or else I will fry it.
Move the yellow to the right and disconnect the white for the moment
Let me see a picture of the downside wire of your switch and a picture of your kill switch...trust me we are getting some where.
We are going to connect the power wire to the left side of the coil which is the positive side and the yellow wire to the negative side. Let me pull a dyna diagram to put you at ease
I'll don't have a power wire for the EI going from the switch to the coil. It's non existent in my harness.
Here is my switch.
Now where is your red wire going from the switch?
The red power wire from the switch is going to that 8 pin connector in the EI. It terminates there. The only wires I have at all related to the coil are the white kill and yellow EI. Sounds like I need a power from the switch to the coil.
yes
Texasstar said:
I am going to post a video for you.
You the man.
I guess the reason it wasn't designed into my harness from Sparck was because I used the stock coil and it had a power wire?
Yes that was the black and white wire at the top of your coil.
Makes sense.
All this still doesn't explain why I can't get continuity... :(. One step at a time I suppose.
