Re: "Patina" The 1973 CB175 Cafe Racer
And why didn't we get a voltage reading when it was connected to the negative terminal on the coil
I found tygon line for fuel and vent. Call around to small engine repair shops. Lawn mower place.
1sttimer said:
Good questions, and why do I have continuity now?
Hard to say without looking at it in person, but I will weigh in on a few points made over the last few pages:
1.) While it technically matters which side of the coil is positive and negative, in practice it doesn't. You can hook it up either way and it will work.
2.) White wire is definitely the power wire. Not yellow.
3.) If everything is turned on and you check for power on the negative side of the coil, you'll (probably) only get a reading if the yellow is unplugged. If everything is left plugged in, the power will flow through the yellow wire to ground and bypass your test light.
on his continuity test...if his power was on to the negative side I understand how it wouldn't work but if his power was off why didn't the continuity test work through the resistor caps?
I'd need some more details of how the test was performed.
Resistance through plugs, caps, and wires can sometimes exceed 25,000 Ohms (depending on setup). Unless a multimeter is used (and in the correct setting), you can get a false negative.
Multimeter was used. And a cheap one at that. I should probably fix that.
Sonreir said:
Were you just using the continuity setting or reading resistance using the Ohmmeter?
I was just reading resistance through the meter. Everything read fine until I screwed the caps on.
10:1 odds says the meter wasn't set to read a high enough resistance level. Switch it over to the 20KΩ and see what you get.
we addressed that
That's where it was set. I was reading 16500 through the wires out the coil. Nothing when I screwed the caps in.
And resistance through the caps alone was fine. About 5k ohm
Sonreir said:
And which two points were being used to measure the continuity?
Tried everything. Through the plug caps, nothing . Through the wires, continuity. Through the coil continuity.
I just realized why fluke voltage ohm meters are called fluke
I thought I wasn't screwing it in the conductor so I tested the wire through the cap and got continuity. Not through the coil that is.
Mine is a Horror Freight version.
Sonreir said:
And how about when to measure between the end of the plug wire and ground?
Hopefully the Guys help me remember but I don't recall measuring that one.
